View Poll Results: Is my 11:1 CR block would be able to handle a SC
11:1 with 6 psi is not an issue/problem
12
80.00%
Should drop the CR and change cam before going sc
3
20.00%
Voters: 15. You may not vote on this poll
Would my block take it or im just pushing my luck ???
Old 03-29-2013, 08:16 PM
always faster
always faster's Avatar
Default Would my block take it or im just pushing my luck ???
Ok i need your input.I already know that some facts about boost but not everything.I know that a good safe CR should be in the low 10 or high 9 but how about 11:1 CR ??? I got a fully forged 383.The quick important specs are:
-11:1 CR with PRC Stage 2.5 ls6 head
-Fully forged block with wiseco pistons(-3cc flat top)with steel top rings, callies rods and crank
-240/244 , 608/612 @ 113lsa
I did make 490whp /461wtq with a stock ls6 intake and tb on 91 oct gas .I could put a Fast 92mm intake and tb to be in the 520whp range but its not what i want.I would like to crack the 600-625 whp range.So a 110 to 135whp gain would be ok.
So if i put a gorgeous black V3-SI kit @ only 6-7psi with 94 octane gas :
-Would i reach the 600whp mark ?
-MOST IMPORTANT QUESTIONS: Is my block gonna take it?I mean by that will it still gonna be reliable or is it pushing to much at 11:1 with this cam...
I know that i could change the heads to drop the cr and maybe i could also change the cam but i really dont wanna do this for now...
Eric
Old 03-29-2013, 08:28 PM
helga203
helga203's Avatar
-Fully forged block with wiseco pistons and callies rods and crank
Eric
It's up to the tune, hope you find a good tuner. You should have fail safe iat's in the tune if your not running meth. But your tuner will know that.
Old 03-29-2013, 08:34 PM
user_name
user_name's Avatar
It might be ok. Hard to say until you see what kind of timing it will take on the dyno. Should easily reach your power goals. You could mix torco in each tank to get 98 octane. I would personally run meth and not be worried at that low boost level.
Old 03-29-2013, 09:43 PM
sami85L98
sami85L98's Avatar
You will be fine with 3.8" pulley, consider spraying methanol as well.
Old 03-29-2013, 10:04 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Old 03-29-2013, 10:46 PM
69ls6
69ls6's Avatar
Stop being a weiner and let it eat..I've got a buddy with a stock block ls6 with 12.5-1 with 26 psi from a turbo making 1050s at wheel..I.ve got 27psi on ls6 block
Old 03-29-2013, 10:57 PM
robert miller
Get your friend to buy this YSI set up then he can give you a run for it.
Old 03-31-2013, 02:12 PM
always faster
-Considering that i got a small UD damper(10% only) how much boost(psi) would i get ?
-Would it be possible to use 91 octane fuel with a good meth kit.Here in my area the 94 is harder to get ?
What meth kit are you suggesting me:
ECS: http://www.eastcoastsupercharging.co...mart&Itemid=29
or
AIS: http://www.alcoholinjectionsystems.c...duct_info.html
Eric
Old 03-31-2013, 04:21 PM
sami85L98
sami85L98's Avatar
Alky control will have landslide victory if you choose as vote system, nothing against the successful kit, i choose cooling mist CMGS kit and braided those plastic hoses comes with kit...price will be same for both kits around 600 bucks...but with cooling mist you will boost gauge and thats also progressive control built in thats plus point i consider to ALky control which is bulky too but performs equal to or better than cooling mist.
Dont you crank pin? i assume so, will be a good time slap a new GM Oem balancer there will yield 8-9 boost with 3.8' pulley, with UD pulley you need to order custom belt ask andy when you order the kit about UD pulley and belt size, so you get the correct belt.
with UD pulley and 3.8" blower pulley, you will be around 6-7 psi boost and boost wont buildup until 4-4500 rpm, never seen realistically but assuming and theoretically it will.
Old 03-31-2013, 05:12 PM
fotoboy
fotoboy's Avatar
ls1 fordged block, 13 psi and climbing and no issues. As stated let the dog eat
Old 04-01-2013, 11:55 AM
undertaker
undertaker's Avatar
Location: ECS : WTF did you break now and HTF did you break it this time
C6Z's are 11.5 out of the box and take 6-7 lbs without problems with meth.
and there are numerous cars with LS6 blocks making 800 rwhp and higher.
I think you'll be ok, not ideal, but ok, but definetely plan on a healthy dosage of straight meth.
Old 04-03-2013, 12:51 AM
silver408z
silver408z's Avatar
You could probably lower your compression by changing heads. Sell the ones you have, buy some that havent been milled and have bigger combustion chambers
Old 04-03-2013, 02:24 AM
fotoboy
fotoboy's Avatar
11.2 compression here and going to over 15 psi. It's all in the tune. Find the right tuner any profit.
Old 04-03-2013, 03:03 AM
winters97gt
winters97gt's Avatar
I agree. I'm not a self tuner like Username, but that's stock LS Compression territory. Lots of guys, including myself have run 10-16psi without issues. BTW, if you're making 500 now, 6-7psi on meth will most likely be 650-700rwhp and will hit hard with that compression.
Old 04-03-2013, 09:41 AM
mchicia1
mchicia1's Avatar
Sell heads and just plop 317s on.
Old 04-03-2013, 11:22 AM
always faster
Callies crank comes with a keyed crank and my TCI 10% UD got a keyway so everything is rock solid with a ARP damper bolts.I did change my oem damper because it was seperating itself(less than 1500miles ago) so i wont take it off.
Hope my english is ok
Old 04-03-2013, 11:29 AM
always faster
So from what i read, i need :
A good meth kit with a 3.8 blower pulley to give me 6-7 psi and a good tuner(i got one of the best in north america)and im in the 650whp area without issue.
Anymore thing that i should be aware ?
Eric
Old 04-06-2013, 06:17 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
Feed her some boost and let her eat!!
The tune is important!!
Get some really good head studs yes I said studs! ARP 2000's or ARP 625+ studs and quality head gaskets (don't skimp out on the exact studs or the exact meth kit!! Don't do it!!
Oh yes and as for the meth kit. Done even look at any meth kit except alkey control.
650 WHP will be cake!!
To Would my block take it or im just pushing my luck ???
Quick Reply: Would my block take it or im just pushing my luck ???
