Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A&A Superchargers
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-22-2013, 12:35 PM   #1
ttz
CF Senior Member
ttz's Avatar
Default Timing table
Anyone willing to share their timing table with me? I'm running HPT SD tune (2 bar). Just rear mounted twin'd my LS6. Meth too of course. I'll be tuning it with the boost as soon as the weather breaks. My current timing table is stock which will of course be too much timing under boost. I'd like to see what others have setup in their tables to get a general baseline to start with. Thanks guys.
ttz is offline   Reply With Quote
Old 02-22-2013, 12:55 PM   #2
p1bz
CF Senior Member
Cam? What injectors. I have an extensive repository. Wont be perfect, but will get you going.
p1bz is offline   Reply With Quote
Old 02-22-2013, 04:48 PM   #3
dsmlights
CF Senior Member
Send a message via AIM to dsmlights Send a message via MSN to dsmlights Send a message via Yahoo to dsmlights
You really do not want someone to share their tables with you as it is just a mix to blow up. Just under higher load turn then down about 12-14 depending on y our compression and go from there. Check for knock, but really should just dial car in and then take to dyno and tune for MBT.
dsmlights is offline   Reply With Quote
Old 02-22-2013, 07:58 PM   #4
ttz
CF Senior Member
ttz's Avatar
Stock LS6 (2001) so stock cam. 71.6lb injectors. Just looking for a good starting point.
Old 02-22-2013, 08:11 PM   #5
p1bz
CF Senior Member
Gimme a bit...email?
Old 02-22-2013, 10:19 PM   #6
Arun@Dasilvamotorsports
Supporting Vendor
Take the low octane table and paste it into the hi-octane table and start from there.
Arun@Dasilvamotorsports is offline   Reply With Quote
Old 02-23-2013, 01:18 AM   #7
Milan
CF Senior Member
Support Corvetteforum!
Milan's Avatar
Send a message via MSN to Milan
You don't want most of our timing tables. Almost everyone on here is centri which means we build damn near the same boost at the same RPM time after time.
What I would do if I was you is go see what cylinder air mass tables you are hitting and at what psi of boost that correlates too and start with 1 degree pulled per psi. Since you are turbo you will probably hit a lot of tables the rest of us will never hit.
I'm not a pro by any means but I haven't blown anything up yet....
Milan is offline   Reply With Quote
Old 02-25-2013, 04:25 PM   #8
Turbo-Geist
CF Senior Member
Turbo-Geist's Avatar
I'll send you one when I get home from when I made mid 500's. It should get you started. Please tell me you will be using a wideband.
Turbo-Geist is offline   Reply With Quote
Old 02-25-2013, 05:17 PM   #9
ttz
CF Senior Member
ttz's Avatar
Of course using a wideband. No other real way to tune. Sounds great. Thanks.
Reload this Page Timing table
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
