2" LT's and a/c line problems......
Old 02-18-2013, 10:53 AM
jmuck
jmuck's Avatar
Default 2" LT's and a/c line problems......
I've seen a few posts on here about the issues people have had when running 2" long tubes and getting their a/c line to fit, and Brett (blownblue) had a great idea with a revamped line. I thought I would share what has worked for me and its a cheap fix.
I was having a hell of a time getting my new a/c line installed when I first got this thing going last year and I actually ended up bending one of the fittings (that goes into the compressor) therefore causing a leak. I kept thinking to myself that there had to be an easier way to get that damn line in around those big *** headers w/out having to loosen all the header and collector bolts. Well I was sitting on the floor with the car on jack stands replacing the brakes when it hit me like a ton of bricks. The opening between the cradle and frame rail there looked to have enough room to wiggle the old line out and the new one in. Well I picked up a new line yesterday and it literally took me 5 minutes to get the old line out and the new one slid into place! Now granted its still kinda of a PITA to get to the bolt and get it snugged up, but this was so much easier than trying to work the line in from the top Also to get rid of the chance of burning through the rubber portion of the line (it is right against the header) I kept the heat shield that comes on it, but I wrap it up tight (there is quite a bit of excess on the aftermarket line) and I put a layer of DEI heat wrap on it. I did the same thing on the first line (it has been on since I finished the build last March) and had no burn holes in the heat wrap I'm sure someone else has already done this, but I haven't read it anywhere and wanted to share.
Old 02-18-2013, 11:47 AM
joshtownsend
joshtownsend's Avatar
I just cut my line and had it rewelded a different angle and a new longer line added...cisted me $50 at some ac big truck place and its been good for bout 1.5 years...dont rember it being a big issie to install either
Old 02-18-2013, 11:59 AM
jmuck
jmuck's Avatar
I have Kooks headers and it was next to impossible getting the block part of the line between the header and compressor when trying to put the line in from the top.
Old 02-18-2013, 12:25 PM
joshtownsend
me too.. ill go home a look at it again..
Old 02-18-2013, 12:31 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Old 02-18-2013, 07:45 PM
SBCGENII
SBCGENII's Avatar
I bent the stock AC line some and wrapped my headers, no problems here.
Old 04-21-2014, 07:04 PM
The Highlander
The Highlander's Avatar
Do you have any pictures of the line?
Old 04-21-2014, 07:16 PM
breecher_7
breecher_7's Avatar
Had no a/c line issues with the 2" ARH units.
Old 04-21-2014, 10:46 PM
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
Same here 2003 with ARH 2".
Old 04-22-2014, 06:52 PM
joshtownsend
best i can do.. when i put it back on the lift, ill try to get a better pic.. but you see it going towards the front and then up and around the header... 2 years no issues now,,
Old 04-22-2014, 07:10 PM
The Highlander
Can you post a picture on the dryer side?
Old 04-22-2014, 07:29 PM
joshtownsend
Here you go.. i also circled the route of the hose and the header for your enjoyment.. i hope this helps with those late nights your guys have in PR!!! I guess you could say us Texas boys do it longer then everyone else and here is the pictures to prove it!!
Old 04-22-2014, 07:47 PM
The Highlander
So you were able to straighten the piece on the dryer without breaking it. Nice.
Old 04-22-2014, 09:11 PM
joshtownsend
oh.. its pretty straight!!!
Old 04-22-2014, 10:42 PM
SteveDoten@ARH
Premium Supporting Vendor
SteveDoten@ARH's Avatar
Lurking......
Old 04-24-2014, 01:01 PM
SBCGENII
SBCGENII's Avatar
Lmao
Old 04-24-2014, 02:34 PM
The Highlander
how about using braided lines for that line? that is actually a very low pressure line right there. 40-60psi...
To 2" LT's and a/c line problems......
Old 04-05-2015, 10:46 PM
blown81bu
blown81bu's Avatar
mine hit and burned through it this weekend...dam 2" headers..removed the line and gonna use heat shield tubing were its rubber
were can u get a new line?
Old 04-06-2015, 01:10 AM
neutron82
neutron82's Avatar
Received 1,260 Likes on 1,055 Posts
HA!
Old 04-09-2015, 10:17 PM
robert miller
Paul you need to also move that stock line as much as possible befor just putting heat rap onto it. I did the same thing and it still burn thur it. I got BLOWNBLUEZO6 his guy made me a totally diff line got it all mover over like the other guy in here as it in the drawing.
Quick Reply: 2" LT's and a/c line problems......
