ECS Alky Control, need instructions
Old 07-30-2013, 08:15 PM
danieloneil01
danieloneil01's Avatar
Default ECS Alky Control, need instructions
If you actually have the PDF file, can you send me a PM and send it to me? I should be getting the meth kit soon but would like to read over it a few times before attempting.
Old 07-30-2013, 09:01 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
Ill upload them when I get time but installation and operation is pretty straight forward.
In the meantime here's a good reference. http://www.cajundude.com/ecsalky.htm
Also you can email Julio he should be able to send you a PDF file of them for your vette.
idoxlr8_70@yahoo.com
Old 07-30-2013, 10:00 PM
danieloneil01
Just emailed him, thanks. Link may work aswell. Appreciate it mang.
Old 08-12-2013, 06:29 PM
Chicago1
Chicago1's Avatar
Ill be using this in a few weeks. anything different from this and Julios file?
Old 08-12-2013, 07:36 PM
danieloneil01
When you ground the MAP sensor MAKE SURE TO HAVE ANOTHER WIRE GOING TO ANOTHER GROUNDING SOURCE. I forgot to ground the MAP sensor and the pump turned on with the key to ACC. I couldn't understand why it was doing this until I noticed I didn't have that ground wire connected. Why they made it this way who knows. It should be the opposite of this. I doubled my grounding source just incase. I don't want the pump to fill the engine with WW and then try to start it if the ground ever became bad.
Julios instructions are good. I will only add that you should splice into the orange wire (ignition) that is to the right of the steering wheel when you remove the cover under it. It's a really simple install but sucks stuffing all that stuff under there.
My pump mounted
Before hiding everything
Old 08-12-2013, 08:35 PM
digivex
digivex's Avatar
http://www.eastcoastsupercharging.co...pac-wiring.pdf
Old 08-12-2013, 08:46 PM
digivex
digivex's Avatar
My pump mounted
Your install looks nice and clean. I got all confused with the wiring and plumbing but was able to cover up my mistakes when I was done
danieloneil01
Like I said above your post I already installed it. And it's nice they finally fixed the dead link.
Old 08-12-2013, 08:48 PM
danieloneil01
Holy mother of Jesus and all that is divine.
Old 08-12-2013, 10:05 PM
MVP'S ZO6
MVP'S ZO6's Avatar
What is all that spaghetti hanging all over??
Old 08-13-2013, 12:18 AM
4DRUSH
4DRUSH's Avatar
Dave's not very good with wiring, he had trouble following the instructions.
Old 08-13-2013, 08:48 AM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes on 657 Posts
I cant believe he spent 64 hrs to install a meth kit.
Old 08-14-2013, 09:13 PM
danieloneil01
So you're saying he's not someone you would hire for meth installs? lol
Old 08-14-2013, 11:43 PM
4DRUSH
4DRUSH's Avatar
Well, he did finish the install, gotta give him credit, but.......
Old 08-15-2013, 12:11 AM
MVP'S ZO6
MVP'S ZO6's Avatar
Old 08-15-2013, 01:16 AM
danieloneil01
What's that orange wire go to?
Old 08-15-2013, 01:27 AM
Chicago1
Chicago1's Avatar
To that one black wire..
Old 08-15-2013, 02:20 AM
danieloneil01
I thought so.
To ECS Alky Control, need instructions
Quick Reply: ECS Alky Control, need instructions
