Looking for pulley size input and belt options 8 rib setup
Old 01-26-2013, 05:47 PM
b16gsr
b16gsr's Avatar
Default Looking for pulley size input and belt options 8 rib setup
Revisiting this as my setup went from a D1 to and F1C
Setup:
5.3L Truck motor
5.3L 799 Casting with intake gasket match, deck and valve job
Tick Performance Custom Blower cam package
Procharger F1C with ????" pulley
A&A 8 rib bracket with Procharger 8 rib pulley's
Innovators West 10% OD balancer
Custom piping to Treadstone intercooler
Custom fuel system for E85
SD 80lb injectors flow matched
I am looking for help on pulley size/boost levels and what my belt options are. Looking at the impeller calculator probably looking at:
Crank Pulley 8
Blower Pulley 4.25
Step up Ratio 5.4
RPM-Engine 6400
Impeller RPM 65054
or
Crank Pulley 8
Blower Pulley 4
Step up Ratio 5.4
RPM-Engine 6400
Impeller RPM 69120
F1C has 74000 RPM max, and I am not looking to max it out. Leaning more towards 4.25.
I will be running the 5.3L truck motor with a cam package spinning it to maybe 6400 or a little more, as I want it to live for a while.
I will be running E85 and am looking for stout power numbers(would be happy at 650whp or above)
Any help appreciated.
Old 01-26-2013, 07:20 PM
joshtownsend
joshtownsend's Avatar
Originally Posted by b16gsr
(would be happy at 600whp or above)
4.0 pulley and 91in belt i believe
Old 01-27-2013, 08:30 AM
helga203
helga203's Avatar
I am need some help, as I have completely changed my build setup over the winter. Sold my A&A V3 Si and picked up a Procharger D1 and placed my order for an A&A 8 rib bracket. I already have a Innovators West 10% OD balancer.
I will be running a stock 5.3L truck motor with a cam package spinning it to maybe 6200 or a little more, as I want it to live for a while.
I will be running E85 and am looking for pretty big power numbers(would be happy at 600whp or above)
Wow 6200rpm's is a walk in the park for that motor. I would under pulley it if you set your rev limit to that and stick with it(yeah right).Go to this site http://ls1tech.com/forums/attachment...calculator.zip. Your going to want max impeller speed at 6200rpm so what ever pulley that is in the calculation will get you there.
Just did calculation if your spinning motor to 6200 then 3.25 if your going to spin to 6400 then 3.5 pulley get you max efficiency out of pro charger.
Old 01-27-2013, 09:38 AM
b16gsr
b16gsr's Avatar
Thank you for that. I will probably go with the 3.5 and work it out from there. Sounds like it is where I want to be.
Old 01-27-2013, 03:17 PM
joshtownsend
I run a 3.55 and an od amd i make 21 psi..far more the 600...
Old 01-27-2013, 03:23 PM
fotoboy
fotoboy's Avatar
8 in balancer / pulley size x 6200 x 4.1 (step up ratio) should equal about 64000ish. Anything less you will be board with.
I also agree 6200 rpm is chump change for a 5.3 IVe been spinning my 5.7 to 6600 for years and I feel Im too safe.
Old 01-27-2013, 07:48 PM
p1bz
p1bz's Avatar
5.3 and 5.7 are identical except for bore.
Old 01-27-2013, 08:38 PM
b16gsr
b16gsr's Avatar
Yea, probably spinning it higher though. These are conservative numbers, trying to be safe.
I am thinking 6400. Not sure I owuld be bored with it, just having fun and don't want to blow it up.
I knew that, but the 5.3 I am using is iron. Bore distortion is less on the 5.3L with boost too.
Old 01-27-2013, 09:04 PM
joshtownsend
go put a 3.5 pulley on it and report back...
Old 04-21-2013, 02:56 PM
b16gsr
b16gsr's Avatar
bumping for different setup
To Looking for pulley size input and belt options 8 rib setup
Quick Reply: Looking for pulley size input and belt options 8 rib setup
