Procharging my cammed c5, looking for help reaching my goals
hey guys, i just picked up a A&A kit with a P1SC for my 99 M6 C5.
my car currently has 1 3/4" ARH longtubes on it with no cats and XS power catback, and has a TSP Torquer V2 232/234 .595/.598 112LSA cam. makes about 390 hp all motor as it sits.
the procharger i picked up has a 4.75 pulley on it.
Im looking to make 575-600 RWHP using 60# injectors, lingenfelter fuel pump and a KB BAP (is it needed?)
my question is, will i need to pulley down in order to make sufficient boost to reach my goals because of my cam selection? also, how do i find out what size belt to go with? im using a new (stock) balancer.
your help is appreciated. im sure ill have a few questions along the way.
6 or 8 rib set up???? I had 6 rib with 3.5 upper pulley with stock 7.25 crank and had 14 psi around 650ish to 700 rwhp.
BTW i tried a 3.1 pulley and got 550rwhp at around 5300rpm 12ish psi boost then major belt slip so it's not worth going smaller then 3.5 when your looking for more power down the road. Just a heads up.
If you are pinning the crank you are only a few more steps away from a cam swap, might as well get something better (bigger).
If it was me I would:
Get a bigger cam
Get the smallest 6 rib pulley I could find (3.4")
And then get water meth because you are going to be making like 750 whp lol
Get a bigger cam
Dont waste your time w a stock even new balancer. I did the same and got about 4000 miles before mine started comming apart. Man up and buy a OVerdrive Innovators West 8 rib. Im still 6 rib for now but can use teh 8 rib till then.
Guys.. perhaps I didn't give all info needed here. The car has a stock shortblock. I don't want to push the thing too far. Its a street car on street tires, radials at the track every once in a while. I'd be happy with just under or exactly 600hp to the wheels. I can pulley it down to 700hp sure, but that's useless to me when it comes to traction and being a street car in my opinion. I know the blower has more in it but whatever I need to do to hit my personal goal is what ill do
The best way to do it is to really put it on and see where the boost is at so then you can order the exact pulley you need. Let me know if you need any help with the install or tuning.
theres a few miscellaneous parts i need and will be calling the guys at A&A tomorrow for them. i know they support vortech kits but i have a procharger with a full A&A new design bracket / kit. i have no idea where to get a pulley, about what size to get, and what size belt to use with this kit and a stock balancer.
A 4.38" pulley will get you 600-650hp with a D1. My stock ls6 motor saw 10-11 psi at 6500 and made 622rwhp. You having a cam should make 650 no problem, probably show a little less boost tho..
again im just shy of 400 rwhp right now. looking to gain 200 rwhp.
the kit is a P1, and not a D1 if that matters.. -Jeremy
A D1 definitely makes more power then a p1, but you can still make an easy 700-750 with a P1 with it pullied down.
For you wanting to make 600hp, I'd probably try a 4.25" pulley on a p1. The faster you spin the blower, the sooner the power comes in, so I'd pulley it down to get it spinning, then limit your upper rpms if you're uncomfortable with the total power it's making. The tune is the key.. But 650hp is in the bag for sure...
Yes.. The boost level is really irrelevant, you just want to make power.
thank you. maybe ill just start there. however i want to have the car trailered to the tuner an hour away, injector swapped there, and tuned on the spot. i doubt theyll have the pulley and belt i need to change while tuning which is why i wanted to get as close as possible before i send her away to tune. i know this 4.75 pulley isnt going to get me close to where i want to be, thus costing me another trip and a re-tune after a pulley swap. i dont even have a belt right now anyway so i was trying to get as close to my goals as i can, order parts once, and be happy with what it comes out to. 550, 570, 600hp. etc. i really dont want more than that. i dont plan on methanol or 8 rib at this time.
any of you guys have any of these said pullies for sale? 4.38, 4.25, 4.10? i need only a pulley and a belt to get this thing done.
also, if i were to leave the 4.75 pulley on it with my setup, any idea what kind of power that would make?
I wouldnt change the cam... You have plenty of cam to make 700hp+...
Pullies and boost levels are always a guess and different for every engine. Just start out with something close, test it, then pulley up or down from there. But you'll need atleast a 4.38" with the stock crank pulley.
