MAP Sensor Question
Old 01-21-2013, 02:56 PM
SuperSteve04Z
SuperSteve04Z's Avatar
Default MAP Sensor Question
I am going to be replacing a few seals in my forged ls6 due to the crankcase pressurizing. Ill be adding a RX Monster catch can to alleviate that problem. While im in there I will be replacing my monster clutch with a Mcleod RXT that Doug(ECS) hooked me up with, adding meth, and pulleying down to a 3.4 from a 3.8. I will also be upgrading the diff with hardened shafts and a brace. My question is, will I have to get a 3 bar map sensor since the 3.8 pulley made 12psi with my setup? If I have to get another sensor, could someone point me in the right direction on how to change it? If you need any other info, let me know. TIA
Greg
Old 01-22-2013, 04:57 PM
SuperSteve04Z
I guess my question is, can the car be tuned above 14 psi with a stock map sensor?
Old 01-22-2013, 05:23 PM
Blitzkrieg
AKA "The CLOWN"
Support Corvetteforum!
Blitzkrieg's Avatar
Doug tuned my car and when I went to SD tune, I needed to get a 2 bar, Doug brought it with him, I think it is a Cobalt sensor? I am at 14lbs if that help you out! I would just shoot Doug a PM and ask him which one to use to be sure! I just got a ZR1 map for my new motor per Dougs recommendation!
Old 01-22-2013, 05:33 PM
Its Bruce
Its Bruce's Avatar
Are you currently SD tuned with a 2 bar sensor? You state stock sensor which is confusing.
Old 01-22-2013, 06:50 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
MVP'S ZO6's Avatar
You should upgrade to the 2bar sensor and 2 bar custom OS.
In the 2 bar OS the kPa limit is 210 kPa if I recall corectly. Please refer to link posted below to determine boost PSI to kPa conversion.
http://forums.corvetteforum.com/c5-f...reference.html
Old 01-24-2013, 02:40 PM
SuperSteve04Z
Im an idiot. I thought that I would have to get a 2 bar map sensor and change the OS if going above 14 psi while still using a maf tune. I am not going SD, so i guess my question is not relevant.
Old 01-24-2013, 03:26 PM
Neil B
Neil B's Avatar
I've run 14 psi on a stock OS MAF tune. You just have to use the PE table for fueling. It's definitely not ideal and very old-school, but it can be done. 2-Bar SD on a custom OS is the way to go in order to get your fueling accurate.
You can also run more the 15 psi on a 2-Bar map. The custom OS allows you to control your VE tables at various kpa's. On a centrifugal blower car, you can add in some extra fueling at the top of the 2-bar sensor range and get away with a few extra lbs. of boost.
To MAP Sensor Question
Quick Reply: MAP Sensor Question
