New-"put your money where your mouth is" build!
Received 1,762 Likes
It's not cheap to do it right
This build includes
Torque plate honing of the cylinders
Line hone mains after doweling and pinning main caps
Square deck block surfaces 90* from main tunnel
Dowel pin main caps
Balancing
Hellfire rings
Speed Pro main
Speed Pro rod
Speed Pro HD babbit cam bearings
Wash, file fit rings, set all oil clearances, final assembly
With all the parts, new LS2 block, K1 billet rods, K1 4340 crank, Wiseco pistons, ARP main and head studs.
Total ends up an easy $5500.
There are alot cheaper alternatives out there but the fellow I deal with builds one engine at a time in a state of the art facility.
I only give out his name to a close friends-so he has time for my builds.
Don't forget-to add to this we still need a new LS2 front cover, valley cover, the kock sensor and cam harness, oil pump, timing chain, camshaft and lifters.
That's why when I sold my last engine combo from top to bottom for 10k-it was a STEAL!!!!!! That's why it sold so quick-there's gonna be one fast, fast car in Finland!
This build includes
Dowel pin main caps
Balancing
Hellfire rings
Speed Pro main
Speed Pro rod
AKA "The CLOWN"
I look forward to seeing his build and how it performs at the 1/2 mile event.
If Arun beats me I will be more than ok with that, he has gone 8.8 and 160mph. His car should be Benchmark, thats his business and he is very good at it!
I just can't compete at his level, but a close 2nd would be cool!
AKA "The CLOWN"
Oh it's me Poppa Bear, I just want to see this thread do well as Arun has put a lot of time and effort into this combo and even though I'm an instigator, I want to see some awesome results and want to see this thread be very informative for those looking for a great FI motor!
AKA "The CLOWN"
Crap here we go............. I forgot about the Rick Monster stepping up his game! This 1/2 mile racing in Monee is getting better and better! Buddy theres going to be some really Big Dawgs there, we need to stick together as Vette guys to hold our own!
I sure hope you come prepared and packing some serious game! I know I will!
#36
Supporting Vendor
Those LSA heads should have a runner volume of almost 275cc when there done.
#37
Around 9.40-to 9.5 but it's going to get a healthy dose of around 26-28lbs of boost.
LS2 block will get the mains pinned and we'll upgrading the piston pins to heavy wall tool steel.
Not messing around with a stock crank/relucter so this is getting a double key-wayed K1, so it should be fine for 7500 rpm shifts.
Cam is going to be something mild to take advantage of the big port LSA head.
#38
Supporting Vendor
I don't see any issues with belt slip-my car typically goes through the traps around 7300 so 200 or so rpm won't hurt much.
On all my logs the boost was always climbing.
Well have to see where these square port heads keep making power too.
