LG 15'' Drag Spindles - Rear Wheel Options
#101
With drag brakes any 15" drag wheel should work. Pretty sure the caliper doesn't stick past hub at all with drag brakes, I will double check mine in the morning
#103
Gotcha I agree as I'm only running drag brakes on the front as well. I went with these wheels as not many vettes are running them. They fit with factory rear brakes. Billet Specialties F body street lites
#106
Well my 16" CCW drag pack finally sold and I ordered the rear set of Weld RT-S (black) wheels in 15x10 w/ 7.5"BS and MT ET Drag tires 26x10
Keeping stock brakes in the rear. Going to be doing strange engineering brakes up front. I'll be ordering the brake kit and front wheels/tires soon. All wheels will be 15" with 25" tall front runners and 26" tall Drag slicks. LG drag spindles are already installed. I'll mount the rims to see if any grinding is necessary for a clean fitment.
Looking forward to seeing the car with 15" wheels and full slicks
#108
Nice, mines torch red too so it gives me a good idea. I'm also considering doing the one piece alumistar 2.0 front runners. A little more pricey, but would look really good too and be lighter weight. Still have some time to decide on that.
#109
#110
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Yeh. It took a lot of grinding. A bit more than I expected, but no where near the point where I thought the strength would be compromised.
#111
I had to grind for the CCW pack as well. So I'm hoping it's already where it needs to be. Thanks for the tip. I know what to look for when the suspension is loaded. The calipers may need some attention for the 15s too though.
#112
Good luck with that. Mine was clearanced for the 16'' CCWs too and there was still a bunch more than needed attention to fit the 15'' Welds.
#115
AMP Racing
I bought my car with the 15" brake kit already installed... That said, there is no grinding required on the control arms. And I believe the brake kit is direct bolt in. The calipers are not in the way of the wheels.
#117
Yes, thread is old & flame suit is on :P
This only applies to stock fender C5s pls, since most 15s come only in 7.5"BS, do they stick out with 275 tire past the fenders? Anyone got decent shots from the back showing how the car sits on 15s?
The correct size for C5 is 15x10 7.5"BS? How about the fronts? Anyone running something in between skinny and wide wheel, something like 7"-8" wide? What would be correct BS to fit without sticking out?
