Finally a REAL 1000cc injector, Bosch Motorsports 1000cc Injectors!!!!!
Are they available in LS3 length?
Former Vendor
connector adapters not height adapters right? It looks like they are only available in extended tip for LS3. If using a GM LS3 manifold that wouldn't work
Former Vendor
I used the extended tip 1200's in my FAST 102 because of how far up the FAST places the injectors over stock.
That is what I am saying. I only see the ls3 style available in extended tip not standard length.
Looks like I'll be on the list for 1000's. My tuner was " like really, these injectors again?" to me when he tuned my FIC 1000's, and 72's. Not that he couldn't do it, but it just took him a bit more time on the SD tune to get the little things perfect since he wouldn't let me take the car back if he wasn't satisfied with the tune. As you know how particular I am now with how my cars drive with our lengthy cam talks, same way with anything that effects the tune. A good tuner will tune any of these injectors to drive good, but the less stress I put on him for the hours of tuning my cars, the better.
Now let's get the parts for the rest of my build in the next couple weeks!
Former Vendor
#33
Former Vendor
They give a much better shot of fuel towards the valve.
I am trying to get a pic of the injector in a LS3 manifold for you.
#35
So it sounds like to run them it would require me to run a FAST which will cost more then just buying IDs and keeping my LS3 manifold. Oh well , it sounded nice.
#36
Former Vendor
Lost of people are using them with no issues whatsoever.
#37
#38
Received 1,762 Likes
#39
Former Vendor
I've been running these for a bit in my 427/ turbo car with super victor intake. The extended tip is the *****. Tuning was real easy. I idle these at 800rpm and can lean it out to 17-1 if I want.
