Does anyone use thread sealant on their nitrous connections?
Old 05-31-2002, 11:55 AM
RDRH8R
RDRH8R's Avatar
Default Does anyone use thread sealant on their nitrous connections?
I was reading some NX literature and they said to use their thread sealant on all pipe thread connections. But to not use it on flare connections, hose, or bottle connections. Does anyone use it? Can you substitue any thread sealant from the local hardware store? Plan on finishing my nitrous install tonight and was curious if I needed to stop by the hardware store before I get home. :confused:
Old 05-31-2002, 03:38 PM
C5Cemo
C5Cemo's Avatar
Default Re: Does anyone use thread sealant on their nitrous connections? (Readsvette)
I used teflon paste for the regular pipe fittings as described...works great.
Old 06-04-2002, 12:53 PM
RDRH8R
RDRH8R's Avatar
Default Re: Does anyone use thread sealant on their nitrous connections? (C5Cemo)
I have tried that twice. I think I might have gotten a bad tube of teflon paste. It does not seem to dry. How long doed it take to dry. I know it won't get crusty dry, but it should not be runny :nono:
Old 06-04-2002, 01:32 PM
EdwardETraylorIII
EdwardETraylorIII's Avatar
I use tape even though they advise against it. You just have to make CERTAIN not to get any IN the fitting/line...
Also - sealant is unnecessary AT the bottle connection.
:seeya
Old 06-04-2002, 08:23 PM
bparker
bparker's Avatar
Yep - use the goo in the tube that comes with the NX Kits.. :cheers:
Old 06-05-2002, 02:56 AM
rwj383
rwj383's Avatar
Default Re: Does anyone use thread sealant on their nitrous connections? (bparker)
I have had bad luck with both paste and tape. Believe it or not, i use JB Weld Quik!!! Really!! It seals tighter than a conflat (UHV jargon) and does break apart easy. I tested this theory before doing all my connections. Now, i can go out to my car after line pressure from bottle to noid has sit static for >24hrs and still have >800psi!!!! No leaks baby!!! I gaurantee if you take soapy water (Snoop) and run it over your connections, you will find leaks.
Old 06-05-2002, 12:06 PM
RDRH8R
RDRH8R's Avatar
Default Re: Does anyone use thread sealant on their nitrous connections? (rwj383)
Do you use it (JB WELD QUIK) on all connections or just the pipe thread ones?
Old 06-06-2002, 07:21 PM
0Sales@MVPAutoParts.com
Former Vendor
Sales@MVPAutoParts.com's Avatar
There is no need to use any sealant with the 4AN/6AN connection. You only need the sealant for NPT (pipe) connections.
:cheers:
-Tuan
Old 06-07-2002, 04:15 AM
C5Cemo
C5Cemo's Avatar
I have noticed the paste seperate before...part teflon, part lubricant. It will still work if it is remixed. I am using Datey - Great White Pipe Joint Compound that I got at Home Depot. I always remove any excess from the fittings so I don't know for sure how long but it will dry all the way up. I crank down the fittings real good and have no leaks...not even right after assembly.
The JB Weld idea is interesting. No doubt it will seal things up :D and solenoids aren't that expensive anyway.
Old 06-07-2002, 04:30 AM
jetskifast
jetskifast's Avatar
For your NPT connections, use Teflon paste. If Teflon paste, does not seal your NPT connections. You have problems with your pipe threads:(
To Does anyone use thread sealant on their nitrous connections?
Quick Reply: Does anyone use thread sealant on their nitrous connections?
