MANTIC CLUTCHES on SALE +++ ALL CLUTCH ACCESSORIES...INSTOCK ready to SHIP Today!!!
Former Vendor
Hello everyone,
We have been involved in Driving, Testing & Installing Mantic Clutches now for alittle over 6 months, so with that said we decided to Drop a few clutch manufactures, so we can focus really hard in helping as many customers
that need & Want The VERY BEST Driving Performance CLUTCH for there application and driving styles...
The Corvette Enthusiast/Customer has always wanted the BEST Of The BEST, there Cake & Eat it Too, well Mantic has Baked that Perfect Cake for YOU..!!!
Mantic has ONLY used the HIGHEST Quality of Materials with Engineering/Designing, made & Tested by the Finest Equipment..!!!
WE Have IT ALL INstock at ALL times, SAME Day Shipping!!!
Eastcoast Performance is your ONE STOP SHOP!!!
***We Save you Time & Money!!!
Mantic 12" Single Disc Dual Friction Clutch with/ER2...$755
The Mantic 12"/300mm Single Disc Clutch has ALL the comforts of an OEM clutch, NO Noise, NO CHATTER, Fantastic Drivability and it HOLDS up to 700hp, only weighs in @46lbs Total, PLUS the Ring-Gear is welded to the Flywheel!!!
Here is what our Mantic Single comes with (Includeds Flywheel, Disc, Pressure Plate, GM HD Throwout Bearing, GM Flywheel Bolts, Mantic Harden Pressure Plate Bolts w/lock washers & Alignment Tool)..And if you would like to upgrade the GM Flywheel Bolts to ARP Flywheel Bolts, its only $39.99...
Mantic Street with ER² is a Clutch Kit specifically designed for the Performance Market. Its New and Unique due to the following combination of features...
ER² Design.???
Patented Pressure Plate ER² design. The groove design enhances the performance in 2 ways. Firstly it increases the Torque Capacity of the Cover Assembly by up to 8% and secondly it assists with cooling which in-turn enables the friction material to operate at lower temperatures and therefore at a higher coefficient of friction. Again this enhances the torque capacity of the clutch...
High strength anti burst SG Iron material used for the Pressure Plate. Performance vehicles typically operate at higher RPM than standard vehicles. To ensure there is no possibility of failure of the pressure plate at these high RPMs it has been manufactured from SG or Spheroidal Graphite Iron. This is 3 times stronger than the standard Grey Cast Iron...
Mantic 9000 Twin Disc System...$1638 ***Limited Time Only*** FREE Slave, Bearings & Bolts!!!
We are stocking 2 different types of Mantic 9000 Twin Disc Systems, they both have the Sprung Street Cerametallic Disc, they both weigh in @ 34.8lbs each total...The difference is the Pressure Plate Diaphragms, the unit with the Standard Diaphragm holds up to 800ftlbs/tq @ the wheels, the HD Diaphragm holds up to 1010ftlbs/tq @ the wheels...
Mantic 9000 Series Clutches are Twin disc, 9” (225mm) diameter modular clutches that are designed for High Performance cars and Track use. Mass is critical for a High Performance clutch to produce the expected Level of Performance, and Mantic offers two levels of low mass clutches to allow you to optimize your vehicle performance to your personal driving style. The Mantic 9000 Series Twins go up to 1010ft lbs (1365nm) of torque drive capability at the wheels!!
The key to the Mantic 9000 SERIES is the street drivability of the Sprung Street Cerametallic discs. These suit high performance engines and enthusiastic driving styles, while allowing excellent drivability when needed. Low pedal effort is another bonus from the 9000 SERIES.
Noise is a common problem on multiple disc clutches when used in High Performance Street applications...Mantic 9000 series features a unique spring clip system on the intermediate plate to remove noise from the clutch...
Sprung Street Cerametallic:
This is a sprung center cushioned button type disc that offers a very high level of performance above organic discs, while offering little compromise in driving style and vehicle usage...
Extra Special Deals on What you need...!!!
Please note:: Our New Clutch Bleeder kits are specificly made for Corvettes...
WE HAVE THE BEST REMOTE CLUTCH SPEED-BLEEDERS ON THE MARKET!! **Made in the USA!!!
ECPC's NEW C5 Corvette Remote Clutch (one-man) SPEED-Bleeder Kit $59.99 w/Clutch Purchase
A 40" Stainless Braided Clear Teflon Coated Line!!
ECPC's NEW C6 Corvette Remote Clutch (one-man) SPEED-Bleeder Kit $69.99 w/Clutch Purchase
ECPC's Remote Clutch Bleeder Protector $29.99 w/Bleeder Kit Purchase
2000 deg Thermo Heat Sleeve for your Bleeder Line
ARP Flywheel & Pressure Plate Bolts Both $59.99 w/Clutch Purchase
GM Flywheel & Pressure Plate Bolts $26.99 w/Clutch Purchase
Clutch Accessories Specials w/clutch purchase....
GM Updated 2004 C5 Z06 Updated Clutch Slave Unit $99.99
GM Updated 2004 C5 Z06 Updated Clutch Master $89.99
GM C5 Z06 HD Throw-out Bearing $39.99
GM C5 Z06 HD Pilot Bearing $14.99
GM C6 Clutch Slave $199.99
GM C6 Clutch Master $119.99
GM C6 LS2,3,7 HD Pilot Bearing $19.99
High-Performance Clutch Fluids
GM DOT4 Clutch & Brake Fluid 8.45oz(250ml) $9.99
Motul RBF600 Clutch & Brake Fluid 16.90oz(500ml) $19.99
TORQUE TUBE ACCESSORIES...
Torque Tube Bearing Kit-Includes(3 Bearings & Dust Shield) $199.99
10mm Input/Output Prop-Shaft Harden Coupler Bolts $7.99each
12mm Input/Output Prop-Shaft Harden Coupler Bolts $8.99each
PLEASE MAKE SURE, & DONT BUY ANY So Called BMW OR EBAY COUPLERS, I GUARENTEE THEY ARE MADE IN CHINA or Taiwan!!!
CORVETTE GUYS, DONT FORGET the couplers!!!
Rubber Torque Tube Couplers
(the good ones, Our units have "Made In GERMANY" casted in the Rubber) German 10mm Rubber Couplers $99.99
(the good ones, Our units have "Made In GERMANY" casted in the Rubber) German 12mm Rubber Couplers $99.99
CARBON FIBER DRIVE SHAFTS(Capable of handling up to 1680ftlbs/tq) on Special $999.99
Billet Aluminum Torque Tube Couplers
ECPC Billet Aluminum Balanced 10mm Couplers $125.99 each
ECPC Billet Aluminum Balanced 12mm Couplers $139.99 each
We sell Mantic, RPS, ACT & our LS9zr6 and of course OEM LS6 & LS7 clutches...Eastcoast Performance-Corvettes is a FULL Service Shop...We average shipping over 350 clutches per year & Install another 100...
Call Mike Yeager to place your order Mon-Sat 9am-7pm est...Sun 1pm-6pm est...1-864-404-1776...
Thanks for your interest..
We accept Visa, MC, Disc, Cashier Check, Direct Deposit & Paypal..!!!
I've had the Mantic single disc clutch in my car for 2 months now it holds really good. I run8-9 lbs. Of boost /with meth. This is really smooth and the best part is the city driving with absolutely no chatter on take off at 800 rpm. My last clutch I won't mention any names but I would to start out at 3000 rpm just to avoid the chatter. Thanks Mike at east coast perf. Like always great customer service.
It's nice to be able to take someone for a ride without chatter.
great deal
Mike Yeager is great he spent about an hour helping me figure out what clutch would suit me best. I have had the Mantic single disc clutch in my car for about 5 months. I have a procharged corvette c5 running 9 lbs of boost. 528 rwhp./505 rwtq. This clutch is awesome feels just like a stock clutch. No chatter when taking off in 1rst. It was a great deal and East Coast Performance is'nt out to just sell you something and make a buck they really help you figure out what you need so you can be happy in the end. I definitely recommend them.
Former Vendor
Thanks, customers like you guys makes our job so enjoyable we are always here to spend as much time as possible to help anyone..
Former Vendor
Thanks for all the orders, we are extending all of these Specials !!!
NO PM's PLEASE!!!
Best & Quickest way is to contact me is directly by phone (Mike Yeager @ 1-864-404-1776)
NO PM's PLEASE!!!
