1,870 HP so far.. New Texas Mile Build
Old 03-20-2012, 03:14 PM
0HinsonSuperCars
Former Vendor
HinsonSuperCars's Avatar
Location: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Default 1,870 HP so far.. New Texas Mile Build
Top Speed Corvette C5 Z06
Built and Tuned by Hinson Motorsports
4-27-2012
We have arrived at the Ohio Mile!
3-23-2012
Unfortunately, we had to postpone the trip to Texas. We simply ran out of time to test before the race, and that is a long haul to ride untested. So we're planning to attend the Ohio Mile, which has 4 events this year. We'll be tested and ready.
3/23/2012
New numbers are in!
2,246 HP @ 7,800 RPM
34 psi
3-20-2012
We made our first pulls on the engine dyno! We made 1,870 horsepower on low timing and 27psi. We're turning up the boost and timing tomorrow. We'll run out of injector around 2,400 horsepower. Special thanks to Young's Performance, Lane Culver, Butler Performance, Ryan Carpenter, Buddy Anderson, and Noah Mitros for making this happen so quickly.
3-20-2012
We are headed for the Texas Mile on March 23-25! We are thrashing to complete the project now (3/20/12). We ran 224 mph on low boost with our previous build. We're looking to beat our own record and eventually compete for the world record for the fastest piston powered car. This new car is a combination of C5 and C6 parts resulting in extreme performance. We have built on the information gained from our previous car, and this ride is looking to push the boundaries for standing mile racing.
Build Specs
Shortblock
427ci RHS Aluminum Tall Deck Block (Assembly & Machining by Butler Performance)
Callies Ultra Center Counter Weight Billet Crankshaft
Aluminum Connecting Rods
Diamond Pistons
Custom High Capacity Oil Pan from Doug Lee Engineuity
Top End
TEA Trickflow 245cc Cylinder Heads
Crower Roller Rocker Arms
Comp Pushrods
Custom Comp Solid Roller Camshaft
GM EFI Carb Style Intake Manifold
Turbo System
Custom Turbo Setup with 118mm Turbo
5" Downpipe
Custom Air/Water Intercooler
Tial Blow Off Valves
Tial Wastegate
Computer & Fuel
Holley EFI Dominator System
Bosch 160 lb Injectors
FuelLab Fuel Pumps & Regulator
Transmission & Rear Differential
RPM TR6060 Transmission
RPM ZR1 Differential with Quaiffe LSD
SPEC Twin Disk Clutch
Roll Cage & Body
25.5 Roll Cage
Custom Adjustable Rear Wing
Wheels & Tires
True Forged Wheels 18x12 & 18x10
Hoosier R6 Tires 345/35/18 & 275/35/18
This is a custom tall deck 427ci solid roller engine built in partnership with Butler Performance. The guys at Butler Performance handle our big cubic engine builds. These RHS blocks are great when they're in capable hands of a great machine shop. Give us a call to help plan your next race engine build.
Getting ready for the engine dyno.
Amazing craftsmanship by the guys at Hinson Motorsports.
Shameless plug for our friends at RHS & Total Engine Airflow/TrickFlow. We stock and use these great manufacturers for our personal and customer use. Let us know how we can help you assemble your next combination of parts!
RHS intake spacers for the tall deck build.
Forced air enters here. Intake is a GM piece with custom fuel rail solution by HINSON Motorsports. An intake elbow plate has been bolted down to the top. We will custom fabricate the elbow to work on this engine.
A billet alternator bracket built by Lane here at the shop. Got amps?
Custom water plates for -12 AN cooling connections. Built in house at Hinson Motorsports.
Custom high capacity oil pan with trap doors for fluid control.
Custom external oil pressure regulator on race oil pan.
Amazing craftsmanship by Buddy & Lane at HINSON Motorsports. Great work guys!
118mm Turbo - It's bigger than you think.
Don't get sucked in
5" Downpipe.
Lots of boost = Twin BOV.
Funny car cage for driver protection. Still under progress when picture was taken.
This is an all business interior featuring a 25.5 cage for protection.
Intercooler and engine water tanks in the trunk. All fabricated in house.
Running a TR6060 and ZR1 differential with Quaiffe LSD. Thanks to RPM Transmissions for their support on the initial build in 2011.
SPEC Twin disk from last year's C6 race car. Thank you SPEC for the continued support in 2012.
High rise hood to clear the intake elbow.
Custom adjustable rear wing.
Rear wing support for additional drag and down force. Braces supported by custom structure built behind the rear bumper.
True Forged 18" wheels.
Looking to put a "2" in front of that horsepower quote.
Old sticker from previous life as a single turbo 76mm. Kinda funny in today's form..
Old 03-20-2012, 03:52 PM
Yellow03Z06
Yellow03Z06's Avatar
Holy crap thats sick!!!
Old 03-20-2012, 04:19 PM
0HinsonSuperCars
Former Vendor
Just added the engine dyno video.
Old 03-20-2012, 04:31 PM
Chris@East Coast Supercharging
Premium Supporting Vendor
Chris@East Coast Supercharging's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Looking good guys
Old 03-20-2012, 04:40 PM
SBCGENII
SBCGENII's Avatar
Glad to see this.
Old 03-20-2012, 04:46 PM
roythomas
roythomas's Avatar
some times people don't understand what needs to be done to break records ..congrats to all hands on your build i admire anyone with passion for a cause ..im sure your happy about this build as well good looking parts list
Old 03-20-2012, 04:55 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
Dam guys you are going for it this time for sure. Just a work of art for sure....Good luck on the new record....Man that thing is for sure one hell of a turbo on a car...Robert
Old 03-20-2012, 04:59 PM
tail_lights
tail_lights's Avatar
Looking more forward to the Mile now, i thought I couldn't get any more psyched!!!!
Old 03-20-2012, 05:10 PM
Robert 2000
Robert 2000's Avatar
Wowzers!!!!!
Old 03-20-2012, 08:32 PM
95wht6spd
95wht6spd's Avatar
Why not use a coupe for better aero?
Old 03-20-2012, 09:02 PM
helga203
helga203's Avatar
Be carefull not to step in front of that sick turbo when it's spinning high rpm's. Freacking suck you in like a jet engine dammmmmmmmmm. Need one of those for my car and toss my f-1.
Old 03-20-2012, 10:27 PM
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Received 1,099 Likes on 810 Posts
Wow that is a sick setup and looking forward to seeing this baby at Beeville
Old 03-21-2012, 01:16 AM
silverc5cu
silverc5cu's Avatar
WTF!!!That TURBO is Half the Size of that Engine...Awesome!!!!!!!!!!!!
Old 03-21-2012, 02:20 AM
bullitt4110
bullitt4110's Avatar
Awesome! Good luck with your goals.
Old 03-21-2012, 06:04 AM
4SFED Z
4SFED Z's Avatar
Damn that is a huge turbo! That is one awedome build. The armagedon package lol. Can't wait to see the numbers. More excited its in a c5 z platform
Old 03-21-2012, 08:31 AM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Nice to see people are still giving the C5 some love.
Can't wait to see what it does once it's turned up.
True Forged wheels look nice! I think I'll get me a set!
Old 03-21-2012, 03:31 PM
Mike04
Mike04's Avatar
Good luck on your goal, awsome build
To 1,870 HP so far.. New Texas Mile Build
Old 03-21-2012, 03:44 PM
SmoothFRC
SmoothFRC's Avatar
I thought the same thing.... Stock for stock, the coupe has a higher top end with 50 less hp....
Maybe just fab'in up a piece to attach the top roof to the rear deck (essentially creating a coupe type airstream)...
Old 03-21-2012, 08:42 PM
bp92gsr
bp92gsr's Avatar
Crazy HP numbers mang! Great looking car and the Fab work is out of this world. Looks so clean and well put together. Great job guys.
Old 03-21-2012, 09:24 PM
cptinjak
cptinjak's Avatar
After all that work/money/time, why bother with an unmodified GM manifold? Seems like a custom piece (equal runner length with a plenum) would be a drop in the bucket compared to the price of the build so far, especially since you have already given up on the stock hood.
Not trying to hate, just wondering out loud. I love this build and I am looking forward to seeing the mile times!
Jack
Quick Reply: 1,870 HP so far.. New Texas Mile Build
