Testing your methanol injection system how to
This is how I test the Alky Control system on the cars that come to me.
I always just pushed my meth test button after turning the meth up and if the car bogged it worked.
Also during a run if the meth LED does not turn green I know to let out.
Very nice fail safe way of fully testing the kit
Obviously the meth system you used was hooked up to the Manifold MAP sensor and not a stand alone 2 BAR MAP sensor, like you can get from Julio! Correct?
The others like myself, would I have to do this test on my stand alone 2 BAR Sensor? Or correct me if I am wrong
Thanks,Matt
Thanks,Matt
Thanks,Matt
Thanks,Matt
You're correct, the only thing that you would have to change is you would grab the vacuum line feeding that other 2-bar MAP and apply pressure to it.
The only issue with that is that pressure will degrade over time. This allows you to get a benchmark and for your system and create a known trend. If you get 150psi and then all of the sudden all you can get is 125, then you need to investigate by checking your electrical connections and possibly send the pump in for a rebuild.
On the Alky control kit, doesnt the LED turn green when the discharge line is at a certain pressure? (like 150 psi or something?)
I usually just hit the test button and listen for the bog as well, then watch for the green light...
I suppose it would be a good idea to pressure test the pump since it is 5 years old.... I do know when I pull the nozzle out and this the test botton it will fog my garage.
Last edited by BLOWNBLUEZ06; 02-23-2012 at 08:46 PM. Reason: clarification from Julio and other members after this post
It's Julio's kit, yes. I choose to use the manifold sensor when I'm doing a speed density setup because there's no sense in buying a 2-bar MAP and power supply from him when you're running a 2-bar sensor on the car and can simply tap into the signal wire. It saves quite a bit when you do it that way and it makes the installation of the Alky kit much easier.
I had mine that way but at one point when the Meth system was set to off it back fed to the 2BAR and wouldn't allow the Vette to start and run - it was kinda crazy but for one reason or another it did it -
I went over with it with Julio and the best thing at that point was to separate it and do a stand alone one
Could not find out why it back fed voltage(checked all connections, ground etc) but once it was turned back on to one of the on settings (#3) all was fine and the MAP got the correct voltage
"BUT" I must say your test set-up is superb and might give it a whirl once I am bck up and running Thanks for the write-up and excellent pics to go along with it
Thanks,Matt
I know Brett I was pulling your leg
Thanks,Matt
Thanks,Matt
It's a legit question that others might want to hear the details anyways.
St. Jude Donor '08-'09
For peace of mind I would have any pump over 2 years old rebuilt or replaced.
I purchased a pressure transducer from Julio awhile back. I can log the pressure in the meth line along with all the other stuff through HP Tuner. You can also get a gauge to hook it up to.
St. Jude Donor '08
Bret, just for a reference, when my meth pump was corroded and went bad, the green LED would never come on.
I still think this test you do it a GREAT idea.
