Auto Swap Thread
Old 01-07-2012, 01:39 AM
corvette8189
corvette8189's Avatar
Default Auto Swap Thread
Well some parts came in today and its about time to get it back together. Auto swap in my 01 Z06.
Level VII RPM 4L65/70E transmission, with billet input, billet
pump rotor, and billet 300M output shaft, SFI Bellhousing, deep
pan, Transbrake
DSS 3.5 in. Driveshaft
DSS Urethane couplers
Corvette SFI flexplate
Cone for Auto flexplate assembly
Coan Converter
Shifter assembly and shifter cable
Auto Torque Tube
PCS TCM-2000 controller and wiring harness
Im posting this for people thinking of doing the swap and for yall to double check my work, make sure i do everything right.
Lets get started
car all torn apart
New Tranny
Flexplate
Lots of wiring
PCS Tranny Controller
Old 01-07-2012, 07:55 AM
Blitzkrieg
AKA "The CLOWN"
Support Corvetteforum!
Blitzkrieg's Avatar
Auto Z06! Sweet, this is going to be a good thread!
Nice choice in parts, looking forward to the finished product!
Old 01-07-2012, 09:12 AM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
I am with you clown... I did mine this last summer.
Old 01-07-2012, 11:37 AM
02402ramair
02402ramair's Avatar
I did my 1st one about 4 or 5 years ago before RPM was selling the conversion harness. I took a 04 Z06 and a 01 auto Vette and converted the Z06 to auto and the auto vette to 6 spd. Since then I have done several more. Not bad once you do the 1st one. I used the factory ECM to control the trans on the ones I have done.
Good luck
Kris
Old 01-07-2012, 01:36 PM
Chris Stewart
Chris Stewart's Avatar
dont forget to do this:
Old 01-07-2012, 01:48 PM
corvette8189
Thanks guys
chris did u use the 6sp brake pedal. somebody told me i needed to get an auto brake pedal if i wanted cruise to work is that right? Or can i just take off the clutch part?
Old 01-07-2012, 02:00 PM
Chris Stewart
Yes I still run the 6spd brake pedal, it saves the hassle if I switch back. I pulled the clutch pedal assembly and covered the hole in the firewall. The original cruise control cancel switch is still in place on the brake pedal. I'm also using the factory computer to control the trans. Might save you some $$$ to return it. I was told I would need a stand alone controller for a 4L80.
Old 01-07-2012, 02:30 PM
corvette8189
Alright cool i havent bought a auto brake pedal so that will work. Im using the seprate computer for the trans via Arun and RPM. im sure they will chime in and give the reasons why they told me to use it.
Old 01-07-2012, 02:35 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
MVP'S ZO6's Avatar
Sweet! Subscribed
Old 01-07-2012, 02:42 PM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Don't forget to zip tie the switch or permanently connect your clutch switch wires before you bother trying to start your car.
Take lots of pictures so dummies like me can figure it out if and when I have a total breakdown and decide to go auto.
Old 01-07-2012, 03:02 PM
Blitzkrieg
AKA "The CLOWN"
Blitzkrieg's Avatar
You may want to watch this thread closely Brett, you just may learn a thing or two so it will be easier when you do yours!
Old 01-07-2012, 03:52 PM
4DRUSH
4DRUSH's Avatar
Been awhile since I had to mess with the stock trans & rear.
As I recall there's a spacer/plate between the rear & auto trans, unlike the manual trans??
Old 01-07-2012, 08:14 PM
02402ramair
The clutch switch wires are run to the neutral safety switch if you want it to work properly
Old 01-07-2012, 08:22 PM
02402ramair
The auto trans uses a seal plate that slides in the diff. This is only used on the auto
Old 01-07-2012, 11:18 PM
corvette8189
pic of seal plate? Thats why i posted this. i dont think i have that
seal plate parts num
plate 12369457 list=42.76
seal 24207010 list=10.96
O-ring 12369456 list=8.88
Old 01-08-2012, 12:13 AM
Chris Stewart
I think the plate is part 12369457 and needs an o-ring. Found a pic here, halfway down the page:
http://tim-yvonne.com/mikemercury/342.htm
Old 01-08-2012, 01:34 AM
CHIWS6
CHIWS6's Avatar
how much have u spent so far on the swap?
To Auto Swap Thread
Old 01-08-2012, 02:58 AM
4DRUSH
4DRUSH's Avatar
Originally Posted by corvette8189
What are all the bolts coming down through the floor pan for?
and where can I buy a pair of those pink jack stands?
Old 01-08-2012, 05:07 AM
baezi z06
baezi z06's Avatar
This i like
i´ll be watching this threat
good luck
Baezi
Old 01-08-2012, 10:30 AM
Z06wanted
Z06wanted's Avatar
When I did my auto conversion it was a PITA but was best mod I done. You will love dragging Bret down the interstate in Mexico. lol Auto for the win.
Quick Reply: Auto Swap Thread
