Msd 2351
Msd 2351
I have a V1 CTSV with STS turbo kit. I just had to replace my 2350 bap with a 2351. Anyone know what MAP to pump volt settings I should use. I have it set to 14 volts flat as of now which does nothing when boost is acheived.
If you're going to keep it then I and many of us crank them all the way up. We even remove the controller and short it out permanently so that it stay's maxed.
