new personal best
new personal best
First and formost got to say a big thanks to Arun at ccp.car is stock long block with small cam,exhaust,meth and a procharger.10.6 lbs on dyno.in the videos boost was down due to belt slip and cooler boot leaking.logged car and founf it was only making 6 to 7 lbs on this pull.also need some input for why the bounces off the line.front shocks are double adjustable and rear are c6z.
http://youtu.be/JQ0ZDmNAmWA
Received 1,762 Likes
mph is down from the belt slip and boost leak[found a hole in one of the boots].car should be around 11psi at track and only 6-7 psi on this pull..I'm shooting for 9s on this setup soon
