Here is my dyno sheet from my 99 C5 A4,only mods are FAST intake,Dynatech headers,Corsa exh,and A&A supercharger.
Would like to thank Mike Norris for the tune,drives great absolutly no problems at all.
Great numbers!!!!! Mike has my 99 now and my numbers are just about the same. Im waiting on a BAP from A&A because my fuel pressure dropped a bit during the dyno run. I also have a 99 A4 with LTH & corsa catbacks.
Thanks - I have a similar setup as you on my 03 A4 (minus the FAST intake) and have it set at 7PSI. Debating with myself if I want to turn up the boost or not.
