Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A&A Superchargers
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-09-2011, 03:08 AM   #1
Juhatee
CF Senior Member
Default Fuel line check valve? Pressure drops after ign OFF.
I have a SXperformance adjustable fuel pressure regulator on fuel rail and RSI twin pump in tank. I use original fuel feed line and I have fabricated a return line. Fuel filter I got from 97-98 model that is lacking the regulator.
If I understand correctly, the one-way valve is located in the fuel feed line between pumps and filter? It's still there because I'm using the original feed line..?
Fuel pressure drops to zero after pumps go off in 10 seconds.
There could be a leak in the regulator too but the fuel pressure is static when pumps are on..
Juhatee is offline   Reply With Quote
Old 03-09-2011, 07:25 AM   #2
Mike04
CF Senior Member
Mike04's Avatar
Your fuel pressure regulator could be designed to always allow some fuel flow through it (doesn't seal completely). I have had one in the past that the manufacturer said would always allow some fuel to flow. It wasn't the brand you have though.
To check you can disconnect the return line and pressurize the system. If fuel flows through the line after the pump is turned off that is where the fuel is bleeding off. You could also cap the return line and momentarily pressurize the system and see if the gauge shows the pressure dropping. Be careful if you do this, you will build pressure really quick because the fuel has nowhere to go, and when you remove the cap the fuel is still pressurized....
Mike04 is offline   Reply With Quote
Old 03-09-2011, 07:33 AM   #3
YeloFevr
CF Senior Member
Hopefully easyvette chimes in...I know he experienced this same problem. One of his injectors was hanging open if I recall correctly??
Are you using 255s?
YeloFevr is offline   Reply With Quote
Old 03-09-2011, 09:03 AM   #4
Juhatee
CF Senior Member
Quote:
Originally Posted by YeloFevr View Post
Are you using 255s?
Yes.
Earlier I had GRJ420P with BAP and I had the same problem then. Of course the same regulator was there also.. Too bad I can't remember if the the pressure drop was present always with that SXperformance regulator.
Old 03-09-2011, 11:07 AM   #5
Max01GreenMachine
CF Senior Member
Cruise-In VI Veteran
Max01GreenMachine's Avatar
Location: ------------------------------- Are you not entertained? ------------------------------- Orlando, FL (UCF)
maxengineering
I see the same scenario with my FPR, fuel pressure (measured at the fuel rail on; on top of injectors) drops after key OFF. I have an Aeromotive FPR on my rails and in the manual it states that it will not hold pressure after the fuel system is shut off.
Quoted from manual: "The enclosed fuel pressure regulator may not hold significant fuel pressure after the fuel pump stops running"
I see the fuel pressure drop little by little, I would say it takes a full minute to go to zero though.
Hope that helps.
Later,
Max
__________________
"The Green Machine" 618 RWHP / 545 RWTQ @ 10 PSI - Jan. 2012
Dark Bowling Green Metallic, Light Oak, MN6 - 317 Ported Heads - 224/232 @114lsa - LS9 Head Gaskets
P1SC-1, Treadstone FMIC, Tial 50mm, 60#s, Racetronix Int./Bosch044 Ext, Aeromotive FPR, 2 Bar SD tune
CCW Classics 18x12 335 MPS, 17x9.5 Nitto 555 - ACT Twin Disc - DTE Brace - Hardened Shafts
LG Pro Long Tube Headers - Borla Stinger 2 Tip - Bilsteins Lowered - VBP Rear Spring - Line Lock - HUD
Max01GreenMachine is online now   Reply With Quote
Old 03-09-2011, 11:21 AM   #6
95vettski
CF Senior Member
95vettski's Avatar
I had a similiar problem and added a check valve up front just before the rails on the feed line. Car starts on the first try and fuel pressure holds all the time.
__________________
04 ZO6 Black/Black ● Champion Motors 402ci
ECS Paxton Novi ● 10.13 @ 149 1.84 60'
909 rwhp 812 rwtq
http://www.youtube.com/watch?v=7QpWNgbBNRs
95vettski is offline   Reply With Quote
Old 03-09-2011, 06:09 PM   #7
easyvette
CF Senior Member
I dont know guys... I am running the aeromotive FPR (boost refferenced) and walbro pumps. And after shut down my fuel pressure drops to 40psi and holds for a long time (hrs). Borrowed a friends aeromotive FPR identical to mine and it worked just like mine. So I am gonna go out on a limb and say it should hold fuel pressure for a while. If your pressure is bleeding off rather quickly my best guess is you have a problem and you need to address it.
I pulled my hair out tracking it down testing the lines and the FPR over and over again. Pulled the fuel pumps to make sure they were not bleeding off. I finally isolated down to a hanging injector. It was my last guess... Probably from cutting braided hoses some dust. When I figured out the problem I was at my witts end and preparing to send my injectors out to get cleaned. As a last resort before sending the injectors out I dumped a bottle Teckron fuel treatment in and 75 miles later I was once again holding fuel pressure after shutting the car off.
Just remember if you are dumping raw fuel into a cylinder after shutting down the car it will find its way into your oil and thin your oil out.
easyvette is offline   Reply With Quote
Old 03-09-2011, 08:31 PM   #8
Mike04
CF Senior Member
Mike04's Avatar
The FPR i metioned above was an Aeromotive also. I talked to them about it and they said it was not designed to hold pressure when the pump was off. I'm running a bigger Aeromotive regulator now that drops about 8lbs of pressure and then hold constent when the pump is turned off. I guess each model doesn't function the same.
Old 03-10-2011, 01:44 PM   #9
JustCruzin
Junior Member
JustCruzin's Avatar
I agree with easyvette. Do you have a hard time starting when hot? A leak in the fpr will back up in the vac hose I think. Check your plugs to see if any are wet. Teckron is great stuff but remember all the crap it loosens up will wind up in the filter and the injector filters as well. Hope this helps a little, Good luck with it.
JustCruzin is offline   Reply With Quote
Reload this Page Fuel line check valve? Pressure drops after ign OFF.
Tags
1986, 1999, c5, c6, check, corvette, drops, fuel, holds, line, loss, preasure, pressure, quickly, valve, valves
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
