****UPP's AFFORDABLE Twin Turbo Kit!!!***
#41
I believe the 1998 stock cam is a 199/208 115.5LSA with .479" lift. The power band on the stock 98 cam is going to force a drop on any turbo like that. If you put in a turbo friendly cam that is a single pattern or reverse split like a 227/224 116, to address the high rpm it would carry the power out way past 6000. I wouldnt think a 199 on a 115 would do much for the power band on any car. Big splits on turbo cams arent a good thing.
Obviously the same turbos on a C6 at 650rwhp/650 shows they arent out of air at 550.
Just because the compressor map reads one thing, doesn't mean the turbine side isn't getting choked to death. .49 housing is a very small housing and will build tons of back pressure, acting just like a clogged cat. Seen that plenty of times as well.
#42
Very cool offering! Hard to decipher from the pics, but is there any ground clearance lost by running the pipes under and over to the fender?
Also, is a battery relocation required?
#43
I'm sure as the power goes up, user # goes up, accumulated total miles on this engineered product increases, etc........many changes will come, the turbo has already been shown as a future area for change.
#44
its a t3 with a .63 ar. Its the back pressure. I have been looking at this kit for awhile on ebay and thats where it sounds like it belongs the builder sounds like a noob. Still need to get rid of the cats though.
#45
Former Vendor
That's more than possible. I do occasionally smell that rotton egg smell. However I know the stock cams power band looks just like this, peak power is at 5900, which is exactly where it is. But the cats may be exagerating the effect. The only reason they were left on was to make selling the car in the emmissions restrictive Denver environment easier. And to demonstrate that with this kit it is possible to use factory cats for those who have to.
They are .63 A/R, not .49.
SBC, I'm not a noob, I've been dealing with turbos for a LONG TIME! I'm not going to sit here and have a discussion with you about A/R, but .63A/R on a twin setup is more than plenty flow. I posted the graphs of cars with one turbo, more than able to flow 500hp worth of exhaust flow through a .63, there is then no reason that having twice the area to flow would suddenly restrict it. The fact that you don't see this, or suggest that (2x).63 is too small on a 550hp car in the first place says that maybe you need to look in the mirror with that noob comment.... (PS, I hate name calling, very immature, I respect and I'm damn knowledgeable in my field.)
-CK
-CK
#46
If you think a 199 intake duration on a 115.5 LSA and a 208 on a 121 will have the same peak HP rpm, you clearly dont know cams. If you put the 199 on a 121 it would carry out 200 more RPM.
#47
Saying you disagree with a point of debate is one thing but insulting the guy and his product is another. I would think calling for cat removal or a cam swap would be a more mature way of approaching the discussion. I dont have the tech knowledge of turbos to comment on the finer points but I do know forum rules.
#48
-Inner fenders are optional, but will require cutting. THERE IS NO PROBLEM WITH HEAT...I've been running this for a while now on my car, never and issue. Remember there is a vent in the fender there that promotes airflow.
-Turbos are not water cooled.
- Oil is scavanged by a Tilton pump
- No removing factory cross memeber.
- Cutting is minimal, a small fg strap where one turbo goes, and a couple holes in the wheel liners for the IC piping.
-CK
VERY interested..
#49
This many?
I think it's time to put your cam software down and try some real-world experience.
If you think that cam is the cause of such a horrible power curve graph, you clearly don't understand cams as they relate to F/I motors.
F/I can take a cam that totally quits at 5500RPM and push the power band far beyond that.
#51
Former Vendor
I don't know why I don't have a better pic, but I'll get one for you. In the mean time this kinda shows.
-CK
#52
You're one of the only people I know that will race their own shadow!
#53
Former Vendor
Let's find out!
I'll post dyno sheets tomorrow, and if need by Spin's got another cam for me to throw in there. I really don't want to go through all that trouble and effort, but if that's what it's going to take to prove the turbos DO flow.....
-CK
-CK
#60
Former Vendor
Both req a bat relocate, but everything needed is included (wire, connectors, etc) just no batter box or anything. But the small drycell batts fit nicely into the rear compartments.
-CK
