****UPP's AFFORDABLE Twin Turbo Kit!!!***
Former Vendor
I have a few off the wall questions.
Is it possible to mod the oil scavaging to gravity feed, into the oil pan?
Would that need a hole drilled through the frame of something?
How does it connect up to the rest of the exhaust? Do you cut the original exhaust? Any tests done without cats?
How long to remove the system? Some of us have to Pass Cali smog
It is possible I suppose to do a oil gravity system, I didn't want to bother with hacking up an expensive oil pan that's hard to remove, I figured a $5 oil cap was a better solution, and pump it back in.
The C6 we did doesn't have cats, the C5 does. How long to remove it is kinda dependat upon you. I'm getting pretty profecient at puting these on and taking them off with all the modifications.
-CK
Former Vendor
-CK
I'm curious about something. If these turbos are good for 550 each, then what is causing them to nose over on the power so badly and so early? With a curve like that, it tells me if you try to turn the boost up, it's only going to get worse.
Former Vendor
A few things.... This is the dyno of the 1998 C5 Automatic.
1st the Auto is just EATing power, plane and simple.
2. This is a 1st gen LS1, weak rod bolts, crappy LS1 intake manifold, and crappy LS1 cam. Same setup on a 01+ would net much better results just from the flow and the cam profile.
3. This is a VERY mild tune, as I had to produce ample power, yet keep it reliable so I have a chance to sell it. It's REALLY lacking timing in the top end. It's on 91oct w/o meth injection. I wanted it to be as simple as possible, because when I imagine selling it, I imagine I'll be selling it to an old man who's never heard of E85.
If you look it's a nice smooth transition, now look at the C6 dyno, the owner didn't quite understand oct ratings, so he had 85 in it. We drained what we could but there was still a mix of crap in there, and on the top end you can see knock retard kick in and pull mad power. Both of these cars are suffering from loss of timing (which effects top end most of all) not lack of turbo....
Here's a couple dynos from other cars that we've done using only ONE of these turbos. (PS Check out the consistancy of the dyno!)
I see that this kit comes with HPtuners, but does it include a tune or simply the module? What kind of tuning support?
Former Vendor
That being said, I'll repost the compressor map. This should squash all questioning about the flow of these turbos.
We don't have a max effor build yet, but Spin has volunteered his car as he's looking to swap to turbos.
The turbine housing is a T3, with a .63A/R.
It does NOT come with a tune. I don't believe in cookie cutter one size fits all tunes. Each and every car should be tuned by a professional dyno tuner. Actually there is some debate, we may be replacing the oil pump with a higher quality pump, and to compensate in cost loosing the HPT. Since we recommend the car being professionally tuned, most tuners already have an interface, and by giving the interface to average Joe who doens't know how to tune, I'm giving him a license to destroy stuff....
Venom, yes this is the price out the door (But Spin and I do accept tips!, or donations to St Judes), but this depends on the power level you're looking for. For a complete list of what all is included:
www.uppcos.com/galleryhtml/ttvette.htm
-CK
#34
Former Vendor
-CK
#37
I think there will be a lot of scepticism until we see (my self included) what this kit is made of on a max effort build.
Looking forward to some #'s with a forged motor and 15+psi.
#38
Former Vendor
Former Vendor
Looking exceptionally good !
I may have a customer lined for a kit - if it comes to fruition we'll run 12 PSI on a 10.0:1 forged bottom end.
Congrats on the product and price point.
#40
Obviously the same turbos on a C6 at 650rwhp/650 shows they arent out of air at 550.
