Finally got the LS7 and YSi to the drag strip, new personal best
That was awesome Mike, great run!!
For the power you are making, change to M15 and M10 nozzles for sure. Tune with the box turned up to 8 and get that meth working for you. And you might as well put a M3 in front of that blower if you really want to get frisky.
Good luck with the re-build, I still need to send my RPM tranny back in for some of those upgrades too.
My mistake, I am running a M10 and M15 currently. My VE table already has a huge trough in it to keep the AFR in the 10s. That YSi is really making some heat pushing 20+ lbs. I'm going to give Julio a call and pick his brain. IAT in the 150 range is way above what I saw with my little S-Trim
Awesome run man!
Sucks losing the trans... Nice run! No doubt the IAT is crazy high. Is your IAT sensor in the meth? I'm thinking the IAT should go down below ambient while it sprays. That's killer you lifted the wheels on a 2600 stall. Transbrake or is the suspension setup that way so you just fart and it goes up?
Former Vendor
Very nice Mike! I'm surprised your IAT temps are that hi. I'm spinning my YSi to 74-75k and my IAT temps never go over 100 degrees, and I'm still using a M10 and M15 nozzle like yourself.
I did pull the front sway bar off the car for the firat time, not sure if that makes that much difference though.
I'll get the tranny off to RPM for an upgrade to a level VII after Thanksgiving.
