Magna Charger TVS 2300 in a C5 Z06
While I was doing my own search, I noticed several people inquiring about it. All I'll say is, Magna Charger has them and they'll be available off-the-shelf shortly, if not already. As for hood clearance, it does require an aftermarket unit and we went with the Lingenfelter Supercharger hood.
Regarding the power - I have no complaints and loving every bit of it. This is a completely stock LS6 with a GMS axle back system. Baseline numbers showed 350 rwhp and jumped to 492 rwhp at just 7 psi. We're still running the factory MAF, so I expect to see additional gains when we step up to the larger 100mm setup.
Overall drivability is exceptional, meaning it's very docile under normal driving conditions and an absolute monster when you get on the loud pedal.
Very nice power gains, I bet the torque is even more impressive!
This is great to see.. I'm very interested in this setup.
However, the 2300 is just barely breathing at that power level.. Considering 500ish rwhp is "normal" for the much smaller 112/122's, I'd like to see what happens when you turn the wick up a bit.
As for the install, Magna Charger was kind enough to handle the work so it went together easily.
Exactly. I've got a few things brewing, so its just a matter of time before we try it.
Here you go:
RPM HP LB-FT
2100 151.0 377.7
2200 164.2 392.1
2300 176.9 404.0
2400 188.3 412.2
2500 199.3 418.7
2600 209.4 422.9
2700 220.5 428.9
2800 230.9 433.2
2900 240.5 435.5
3000 250.5 438.6
3100 260.0 440.6
3200 268.4 440.6
3300 276.8 440.5
3400 285.3 440.8
3500 295.2 442.9
3600 304.5 444.2
3700 312.7 443.8
3800 321.9 444.9
3900 331.7 446.7
4000 341.6 448.6
4100 350.6 449.1
4200 359.3 449.3
4300 368.5 450.1
4400 377.5 450.6
4500 386.1 450.6
4600 393.5 449.3
4700 401.8 449.0
4800 408.5 447.0
4900 416.1 446.0
5000 424.0 445.4
5100 431.2 444.0
5200 437.7 442.1
5300 443.2 439.2
5400 447.8 435.5
5500 453.1 432.6
5600 457.8 429.4
5700 462.1 425.8
5800 466.1 422.1
5900 469.7 418.1
6000 474.9 415.7
6100 479.4 412.8
6200 482.7 408.9
6300 486.0 405.2
6400 490.0 402.1
6500 492.2 397.7
RPM HP LB-FT
2100 151.0 377.7
2200 164.2 392.1
2300 176.9 404.0
2400 188.3 412.2
2500 199.3 418.7
2600 209.4 422.9
2700 220.5 428.9
2800 230.9 433.2
2900 240.5 435.5
3000 250.5 438.6
3100 260.0 440.6
3200 268.4 440.6
3300 276.8 440.5
3400 285.3 440.8
3500 295.2 442.9
3600 304.5 444.2
3700 312.7 443.8
3800 321.9 444.9
3900 331.7 446.7
4000 341.6 448.6
4100 350.6 449.1
4200 359.3 449.3
4300 368.5 450.1
4400 377.5 450.6
4500 386.1 450.6
4600 393.5 449.3
4700 401.8 449.0
4800 408.5 447.0
4900 416.1 446.0
5000 424.0 445.4
5100 431.2 444.0
5200 437.7 442.1
5300 443.2 439.2
5400 447.8 435.5
5500 453.1 432.6
5600 457.8 429.4
5700 462.1 425.8
5800 466.1 422.1
5900 469.7 418.1
6000 474.9 415.7
6100 479.4 412.8
6200 482.7 408.9
6300 486.0 405.2
6400 490.0 402.1
6500 492.2 397.7
