02 Z06 A&A kit
02 Z06 A&A t trim kit results
the set up is
A&A supercharger kit V3 t trim 3.8 pulley
A&A blower cam
Patriot stage 2 head
Fast 90
snow performance meth kit
http://www.youtube.com/watch?v=69mJX...layer_embedded
A&A blower cam
Fast 90
stock bottom end car. the car made 8 to 9 lbs of boost. hope to order a smaller pulley to see if it will get me over the 700 mark
good #s and good to hear A & A is doing a build like this for me,
Forged LS6 short block (stock cubic inches) Includes LS6 block torque plate
honed to 3.905, Diamond forged pistons (8.6 CC dish), Akerly & Childs file fit
rings, forged 6.125" connecting rods, OE crankshaft
Custom grind A&A camshaft
HD adjustable timing set
GM Performance oil pump
ARP main studs
Patriot CNC ported heads with stainless valves, dual springs, titanium
retainers, hardened locks and new seals
ARP head studs
GM Performance lifters
A&A supercharger system with T Trim upgrade.(self contained)
Upgrade to 8 rib belt drive
add Boost A Pump to system (in tank pump is included)
Methanol injection kit
ARP main studs
ARP head studs
that 8 rib will definitely help you out you will probably see over 10 pounds of boost with it. my belt was slipping some so that will be my next purchase is the 8 rib and a smaller pulley.
