Is 3 minutes WOT unreasonable?
#41
We have more endurance experience than anyone you'll find on any automotive forums. We (Virginia Speed) has run endurance R&D programs for the Military as well as private companies. We (they) know what it takes to make an engine last at full power WOT for extended periods of time. We've dynoed marine engines at WOT for literally hundreds of hours on end.
Call superflow, and ask them how Roushe can run cup motors all day, but we broke the very same dyno they use. Reason; because they (superflow dynos) weren't meant to run 650 inch big blocks that make 750 ft lbs at 3500 rpms for 8 hours straight!!! Now we have a diesel endurance dyno, and have run engines as long as 400 hours, just to see what happens to them.
The knowledge gained from these programs is applied to our automotive engine packages. This is extremely valuable knowledge few individuals or shops in this industry have. We're lucky that we're in a position to acquire these types of contracts.
So, basically, there are few people in this business, that can tell you with confidence, and from EXPERIENCE, what parts are needed to make a certain combination last. I doubt you will find anyone on here, or any other automotive forum that has built this kind of engine to run at that level of power for that long.
Thanks (both of you above) for stopping in and posting your qualifications and not actually adding value to the question at hand.
The texas mile is hell on cars. That pull is ~ 23 seconds of WOT at 1000 rwhp.
The cooling system and every other aspect of the car must be up to the task as well.
I would run a Callies Magnum/carillo(Dyers/lunati billet, etc) connecting rod, and a good forged piston.
Our endurance cars run many many hours on track. They must be built with that in mind. cooling on a 6 second 200 mph drag car takes a totally different approach than a 24 hour endurance car.
Plan the work, and work the plan. Set a goal, and build to it with a safety factor built into your goal, and you will be fine
#42
Will we be seeing you at the TX mile as well?
#44
#47
EDIT: Interestingly, a stock C6Z will do the standing mile in 29.3 seconds and be doing close to 175mph. The 175 was essentially terminal velocity so it would need 1.4 minutes to get through the next 4 miles, meaning it needs to run WOT for 2minutes.
#48
I got my info from this article in Motortrend that did some testing on high HP cars and standing miles. It should give some insight.
http://www.motortrend.com/roadtests/...e_testing.html
#51
This will be my 3rd trip to the TX Mile and I LOVE IT! God (and Taylor) willing, I hope to join that 200+ MPH Club this time!
#52
No Problem! Fast, Slow or somewhere in between, I'm just glad there are so many people interested in the TX Mile to keep it going year after year!
#53
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
We did bring 2 cars out there and both did very well. No way at anytime were either anywhere near WOT for 3 minutes though. The Silver state classic is all about cooling. We had to back down on Dougs car being it was an automatic and we should have been running larger coolers. We just wanted the experience to see how the cars performed. We would love to try running the standing mile. Unfortunately there have been none local to us as of yet.
#54
I am assuming it's more a time thing for you busy dudes. Maybe whoever draws the longer straw between you and Doug can bring your car down on the trailer.
#55
DRM built my 417 iron block stroker short block over 7 years ago............I have put 13K hard drag racing/road racing miles on it w/o issue. Not FI to be sure, but 500 na at the wheels through an A4 that will take VIR for 2 days.......and a 150 shot for looks.....
I have broken trannys/rears and valve springs.........the motor burns a little oil and I will not know for sure what he used until it breaks one day. Suppose to be Callies/lunati.......He has a good rotating assembly in it for sure
Good luck on your goal!
