want to add TT`s on my 99 C5 what should i do?
I found some twin turbo kits on the internet and im really interested in installing one of them hat i wanted to know what should i do i mean are there any special preparations i should keep in mind for a turbo kit so that i won’t go screwing up my engine i have a 99 C5 Auto-trans do u guys have any advices for be before going on with it
save up alot of money. Fi is not cheap
be sure to add in all the supporting mods to your cost list. Injectors, clutch, tuning, ect.....
Ride with some people that have the systems you are interested in. get REAL WORLD INFO, not just what the magazine says. What are your LONG TERM goals?? That will help dictate what system, and what mods, and how much you may spend.
For example, I built my system,, custom, 1 off. I have over 13k WITH supporting mods for the system. Now add another 7-8K for the motor I am needing replaced.
Dont listen to X system is better than Y system. Everyone has their opinion of which is superior. Dont get caught up in numbers, its TOO easy to make 800RWHP, but at what cost.
Received 1,194 Likes
St. Jude Donor '15
in short, the stock bottom end won't last too long on turbo's.
You'll need thousands $$$ of drive train upgrades for new tranny, differential, brace, tranny cooler, oil cooler, torque tube upgrades, etc .. to hold 600 RWHP.
If you do a lot of the work yourself, except a $20K minimum investment and that does not include the motor.
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
I was in for $13K on a budget setup on my 99 -- APS Turbo kit, Comp 918's, Tex OZ-700 clutch w/04 ZO6 hydraulics, ECS Meth kit, 2Bar SD Tune, Lingenfelter Fuel Pump, Mototron 60# injectors, Gauges, installation. That was with ZERO drivetrain upgrades, though it included Bilstein shocks because the APS didn't work with the F45 Selective Ride Control.
It's expensive. For an initial estimate that is just to get you up and running around, take the cost of teh turbo kit and double it is what I'd say. Then go from there.
To really do your homework before you start buying parts and tearing apart your car.
Which turbo kit(s) are you considering?
At a minimum you'll need to upgrade the fuel system and the transmission or clutch (or both) depending on desired power level.
Received 1,762 Likes
unless you have the money are able to do alot of work your self. LEAVE IT STOCK ARE JUST DO HEAD AND CAM AND INTAKE AND T.B. WITH EXHAUST. AND THAT IS IT. WHAT EVER YOU DO IF CANT GO ALL THE WAY WITH THE CAR DONT HALF AZZ DO IT OR YOU WILL BE BROKEN DOWN FOR A LONG TIME....
Former Vendor
Rob.
Well here is an idea. Sell your car and buy one out of the forsale forum. There are plenty cars in there already up and running for cheap compared to what you will spend on this. JMO
What they said....kinda.
I read the above responses and it was all very good advice and very accurate. Also not necessarily true. Let me explain. If you are going to go and get bit by the "F/I hp bug" and start racing dynos or hitting the dragstrip on a regular basis then you had better follow what the guys above are saying. It will save you a tremendous amount of grief and money in the long run.
That being said, lets do a reality check. You DON'T need to build a beast car that is so modded it requires everything in the car be upgraded. I mean really if you want to do it correctly they are shorting the money thing by a long way with the above estimates. You SHOULD get new big brakes ($6k), you should redo the suspension with some coilovers and new sway bars and all that ($4K), you should also get some bigger wheels tires for the backs to handle the extra power, oh also fronts too to fit those big new front brakes, oh and also a full cage if you ever want to take it to any sanctioned event with insurance or be able to open the doors if you get it to hook up. So basically you should replace the entire car so might as well buy one where someone else has already eaten the depreciation on the hop up parts.
I also think thats total if you just want a noticeable hp upgrade without going insane. I bought an off the shelf Procharger kit for my old '87 vette nearly 12 years ago. It took me nearly a decade and 175mph for ten minutes straight at an open road race to finally blow up my stock original motor with 90k miles on it. The old L98 is not nearly as tough a motor as an LSx either. So here is the deal. If you get a 'basic' F/I kit, like an STS TT rear mount or something depending on smog laws in your area and then LEAVE THE KIT STOCK, don't go shooting for 20lbs of boost or having the tuner try to put on his special 'super whammy ultra lean high hp tune' on it, the kit and your car will last a long time without any problems at all.
This only assumes that the car is in good mechanical condition to accept a base kit to START with. If it is, then find a trustworthy local shop to do the install if you aren't mechanically inclined, have them install it and go have yourself a ton of fun for a long time. It's not all doom and gloom.
But heed the above advice...if you go screwing with the base kits and get all horsepower happy, you will be buying a lot of expensive replacement parts to keep chasing the 'weak link in the chain'. That can get really old really fast. So be honest with yourself up front and ask yourself what you want to do with it. You can see where the hp addicts on this forum end up, and I admit I am the same. Budget accordingly.
First of all id like to thank all you guys for your responses and help and suggestions it really gave me a good idea.
well regarding the subject of selling my own car and getting a new one with all mods already done i would have loved to do that but unfortunately im not livin in the stats all the time so i take my car back with me when i leave and this year my stupid government made a new rule to help car dealers which is i cant bring a car older than 5 years to the country so that means no one can import a car older then 2005MY so that Idea is Xed
see to be honest i don’t want a real beast of a car i have an 08 ZO6 an F430 & SL63 and the C5 being my 1st vette i never sold it and i still love it, i just want the car to be in the same power level as all the other im not a drag strip junky i just need some extra power when i hit the pedal.
and regarding talking and getting info from other guys with turbos on their cars it’s a bit hard cause i only know 3 my cousin who has a linginfilter TT and he got his all ready and tuned up so no help from him and 2 other guys with STS turbos who just went in installed them and dont know **** about the system i mean it isn’t even working properly they are paying KKKK$ trying to making them work but they keep on going to the wrong people one had like 506 on the wheel and the other had 480 and they have C5Z`s
regarding the budget i have no problem the thing is im gona be buying everything online and then shipping it overseas all the way to Jeddah so i just dont wana make the wrong choice thats why im askin you guys who had experience with turbos i mean i can read and read and read but just 5 mins talk with someone who actually experienced it can give me more info now i am kind of mixed up should i get it or shouldn’t i mean i dont wana go with it and then keep on coming and going to the workshop for the rest of my life
Yes.
The only issue that you might run into is belt alignment and possibly overheating (TT also). In the states it would be easy to find an installer who would take care of the issue, in a different country, that's a whole 'nother ball game.
It sounds like you have quite a stable of cars
Have you ever had a modded car before? Once you mod, things change quite a bit.
The 99 model year engine is not the strongest. Later years had stronger engines. The transmission is definately going to be a weak point.
Are you near the UAE? If so I know someone who has a supercharged C5 there. There's also someone who has a TT C5 there as well. If you're close, PM me and I'll give you their contact information.
