procharger oil changing tips
The first time I changed my oil on my head unit it was a mess. I've read somewhere on this forum that you can suction the fluid out from the top.
My kit came with a braided metal extension hose for the drain that has a drain plug on it. The kit also came with a syringe for filling it. No mess!
If you don't have these you could probably order them from ATI.
I bought a syringe for the auto motive section of Wal-mart and some very small tubing 1/8 inch IIRC and heated it up to expand over the tip of the syringe and when the charger is cool take the plug out and suck out the oil. I also use it to fill be removing the plunger and pouring the oil into the tub and it fills it up no mess! this kit looks nice too
A large catch pan (For Spill over) under the Vette, a faily good sized funnel with a rubber tube attached going into the catch pan. Uncork the plug and let her drain into the funnel.
You can use a socket on an extension and once it is loose get ready ready to catch it! (kinda like the oil drain plug, you always get some on your hand )
Completely drain and re-fill with 6 oz of ProCharger fluid
Thanks,Matt
Thanks,Matt
I just let my dad do it when he changes my oil He says its a piece of cake
Former Vendor
Out of the top is ok, for a few oil changes, but I suggest after every 3rd oil change you pull the drain plug off just to get and sediment off of the magnet on the plug. Keeping the sediment out will ensure long life for the oil seals
my plan is that i would like to suck it out the top first, then pull the plug and install the procharger draining kit. So where can i buy this $25 mity vac? any links? thanks mike
Former Vendor
go to your nearest napa or dependable parts store they carry plastic three once syringe its about 5 bucks, buy a foot long clear plastic tubing to fit the syringe remove the screw from the top of the supercharger suck the oil out replace it with new 8 once oil..
simple
simple
Banned Scam/Spammer
Do what I did...
Use the pump from your ***** enlarger (that never worked anyway) and pump it out.
oh, works great for bleeding brakes & clutch too.
