Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A & A Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Closed Thread
Old 08-02-2009, 04:01 PM   #1
02402ramair
CF Senior Member
02402ramair's Avatar
Default ZO6wanted (Shane) 418ci TTix build
Shane decided to go with a new combo after having bad results out of his 403 2.8 Kenne bell setup. Shane sold off everything but his heads. This is the new build. As of right now we have the long block built. Intake and exhaust manifolds need to be ported and the engine will be ready for install. This is a high compression turbo build. We know 10.8 is high. That's what we wanted so no need to bash the compression.
Motor
418 LS3 10.8 to 1
Diamond -4cc Flat top pistons
Callies rods
Callies 4 inch stroker crank
ET Performance 255 heads
Fast 92 intake
TTIX Turbo kit
twin 62 mm Turbonetics ball bearing turbos
[/quote]
02402ramair is offline
Old 08-02-2009, 04:03 PM   #2
02402ramair
CF Senior Member
Old 08-02-2009, 04:03 PM   #3
02402ramair
CF Senior Member
Old 08-02-2009, 04:05 PM   #4
02402ramair
CF Senior Member
LS2 conversion, oil pump, Double roller timing chain, Under drive pulley
ported and shimmed oil pump
mock up
Old 08-02-2009, 04:06 PM   #5
02402ramair
CF Senior Member
money shot
Clearancing the motor mount for the turbo inlet
Also we installed the cam.
Old 08-02-2009, 04:08 PM   #6
02402ramair
CF Senior Member
A pic of oil drains
a pic of windage tray
A pic of oil line to the passenger turbo run.
Old 08-02-2009, 04:09 PM   #7
02402ramair
CF Senior Member
Oil jet for the turbo.
The oil lines plumbed for preasure.
Oil return from turbo.
Shane took heads over to be surfaced and valve job done.
After we put them back together.
Old 08-02-2009, 04:10 PM   #8
02402ramair
CF Senior Member
New injectors. How about 93lb an hour. lol
Old 08-02-2009, 04:11 PM   #9
02402ramair
CF Senior Member
L19 head studs
Old 08-02-2009, 04:12 PM   #10
02402ramair
CF Senior Member
New Fast intake 92mm and fuel rails
Old 08-02-2009, 04:13 PM   #11
Z06PSI
CF Senior Member
What happened with the old 403 pistons?
Z06PSI is offline
Old 08-02-2009, 04:22 PM   #12
02402ramair
CF Senior Member
Quote:
Nothing. He sold the short block and sold the blower. Both were still good. It just didn't perform as needed. He decided to build a new combo instead of fixing the problems with the old combo. Good choice IMO.
Old 08-02-2009, 04:23 PM   #13
master blaster
CF Senior Member
I see your aviator pic says 9.81 @ 139
What setup did you have then?
master blaster is offline
Old 08-02-2009, 04:27 PM   #14
02402ramair
CF Senior Member
That is my car. I have a Ls3 418, AFR 225, Fast 90, 12 t0 1 on spray. I am building this for Shane (Z06wanted)
Old 08-02-2009, 04:36 PM   #15
MyFirstCorvette
CF Senior Member
MyFirstCorvette's Avatar
Quote:
Where you on Pinks?
I saw a black vert running 9's..
MyFirstCorvette is offline
Old 08-02-2009, 04:40 PM   #16
Nick James
Junior Member
Thats going to be a crazy outcome!
Nick James is offline
Old 08-02-2009, 04:40 PM   #17
02402ramair
CF Senior Member
I ran the 9.80 at pinks but was not on the show. It was a 9.80 field too. I thought for sure I would be picked but was not. Could be that I didn't have a roll bar. Don't know for sure. That was the first 1/4 mile pass for the car. It was a 100 shot pass. I have a lot more spray so it should go a little quicker.
Old 08-02-2009, 04:45 PM   #18
02402ramair
CF Senior Member
It should be pretty nasty. His goal is to run with me or faster. We run 1000 ft due to no 1/4 tracks close. My car runs 8.50 (1000ft) on motor and he couldn't stand that I would wear his ass out and he had more power. This combo should run good
Old 08-02-2009, 04:52 PM   #19
Chris Stewart
CF Senior Member
Chris Stewart's Avatar
Looks great, he's going to like this ALOT.
for the results. Going to run meth?
__________________
2003 Z06
TTiX @ 15psi, LME 347
9.67@145.93, 1.50 60'
utube vid
Chris Stewart is offline
Old 08-02-2009, 04:55 PM   #20
02402ramair
CF Senior Member
Meth is a must and yes it's going to run LOTS of meth. lol
Reload this Page ZO6wanted (Shane) 418ci TTix build
Closed Thread
Tags
418, arkansas, build, built, c5, cookeville, corvette, dyno, forums, ls3, miller, rob, rock, tn, ttix, turbo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
