Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A & A Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-12-2009, 05:18 AM   #1
Zosickness
CF Senior Member
2004 Chevrolet Corvette
Zosickness's Avatar
Default My Kenne Bell results
Quick recap:
418 ci
TFS 235cc
248/254 .622/.622 108LSA
Kenne Bell 2.8
Meth injection for safety
The car is pullied for 13 pounds, but my NA cam is bleeding some boost. The car has since been dropped off to get a blower cam and raise boost to 16 psi.
This is at 8 psi with the NA cam.
http://s187.photobucket.com/albums/x...626hp_0001.flv
Here is the dyno sheet also.
Zosickness is online now   Reply With Quote
Old 06-12-2009, 07:51 AM   #2
vrybad
CF Senior Member
Nice results.
With the proper blower cam, I could definitely see it picking up a bit across the powerband.
vrybad is offline   Reply With Quote
Old 06-12-2009, 07:57 AM   #3
breecher_7
CF Senior Member
Thats way low for that setup, especially for those cubes and that boost. How much timing is in it? Whats the compression ratio?
Thats not right at all. Considering your running on a dynojet, you should be MUCH closer if not over 700hp with that. Not trying to bust your bubble but somthing not right. Sure Jeff will step in.
We went over 700 with a crap cam on a 364 with the 2.6 unit on 93 with Meth, that was on a mustang dyno. Now granted that was on 13psi, not 8. But you have alot more cubes. There is ALOT left in that thing! Even if that is the one load cell dyno dynojet makes, that number is still very low or tune ULTRA conservatively.
breecher_7 is offline   Reply With Quote
Old 06-12-2009, 08:40 AM   #4
willig5
CF Senior Member
willig5's Avatar
Nice numbers I am sure they will come up some with your new cam.
Be careful with your new power.
willig5 is offline   Reply With Quote
Old 06-12-2009, 11:18 AM   #5
stainless40cal
CF Senior Member
Its the cam, jeff saw his combo before and agreed. Thats a big cam for a n/a 418 let alone a blown one and on a 108 lsa i can see what its not making much power it could be bleeding off nearly 7-8 psi off boost
stainless40cal is offline   Reply With Quote
Old 06-12-2009, 11:22 AM   #6
slothy
is laughing at you!
Support Corvetteforum!
slothy's Avatar
Send a message via AIM to slothy Send a message via Yahoo to slothy
108....i wanna see a video of this idle'n! lol
slothy is offline   Reply With Quote
Old 06-12-2009, 11:40 AM   #7
Zosickness
CF Senior Member
Zosickness's Avatar
Quote:
Originally Posted by vrybad View Post
Nice results.
For sure.
It's the cam.
Quote:
I had that cam spec'd out for when I had my super vic intake setup. It's bleeding alot of boost.
Quote:
Watch the dyno vid up top. Got a nice idle too it.
Old 06-12-2009, 11:43 AM   #8
Zosickness
CF Senior Member
Zosickness's Avatar
Yeah. Should come up.
I need more powah!
Old 06-12-2009, 11:55 AM   #9
slothy
is laughing at you!
slothy's Avatar
ya after i posted i noticed link... hehe sound good.
Old 06-12-2009, 12:08 PM   #10
madmatt9471
CF Senior Member
1998 Chevrolet Corvette
madmatt9471's Avatar
Location: Palmdale, Ca 1/4 10.34 @ 135 MPH - 701RWHP & 582RWTQ
Very nice numbers indeed and with the new cam and less ovelap it'll be wayyyy better!
I noticed on your Dyno sheet it was the STD Smoothing, what are your numbers @ the SAE Smoothing?
Thanks,Matt
__________________
'98 LS1 Vette-Email madmatt9471@sbcglobal.net Cell 661-406-7516
TFS Heads,Cam,Kooks LT's,HiFlow Cats,XPipe----400RWHP & 400RWTQ
NewCam224/228 581/588 114 Yank 3200 3.42s----423RWHP & 399RWTQ
ProCharger P1SC 3.85" Pulley 7.6 PSI Boost----------565RWHP & 483RWTQ
Meth Injection2BAR SDTune(Est720 HP@Crank)---------591RWHP & 496RWTQ
Forged3473.2"Pulley12PSI Boost(Est780HP@Crank)---------639RWHP & 540RWTQ
FlipDrive,RadLyDwn,4"CAI,14.4Boost,80#Inj(Est854 HP@Crank)701RWHP & 582RWTQ
madmatt9471 is online now   Reply With Quote
Old 06-12-2009, 12:30 PM   #11
Zosickness
CF Senior Member
Zosickness's Avatar
Thanks,Matt
I'm not sure about the SAE numbers.
I can give you the run conditions, but that's the best i can do:
98.13 F, 29.03 in-Hg, Humidity 35%, Std 1.07
Old 06-12-2009, 12:49 PM   #12
stainless40cal
CF Senior Member
Quote:
Originally Posted by Zosickness View Post
I'm not sure about the SAE numbers. At the time I just wanted to get the car running so I could start working out the bugs. I wasn't really worried about numbers. More worried about my butt dyno. It was feeling awesome, but now i'm back in Afghanistan. Most of the bugs are worked out now. Like the rocker arm bolts that snapped on my new heads. Now, all i can do is wait for the new cam and pulley to get put on.
You will be more than happy soon enough man when you get that new cam in, up the boost, and get a good tune in her she will be
Old 06-12-2009, 12:55 PM   #13
03blackZ06
CF Senior Member
you should be well into the 700's if not 800's with the right blower cam. make it happen asap
03blackZ06 is offline   Reply With Quote
Old 06-12-2009, 03:50 PM   #14
Jeff @ TPE
Supporting Vendor
St. Jude Donor '06
Jeff @ TPE's Avatar
Send a message via AIM to Jeff @ TPE
Its not only the cam, but 8psi on a 2.8H is WAYYYY to low. The absolute minimum allowable boost on a 2.8H is right about 13psi.
Along with that 418" motor, that thing is just swallowing up the boost. Turn the wick up, and you will make more power.
Also, watch the vacuum in that inlet when you turn the boost up.
Quote:
Jeff @ TPE is offline   Reply With Quote
Old 06-12-2009, 05:55 PM   #15
02402ramair
CF Senior Member
02402ramair's Avatar
I think he said it was pullied to make 13 but only makes 8. I would think the blower should be in its efficiency range with a 13lb pulley. Sounds like the cam is bleeding off the boost.
What compression is this motor running?
02402ramair is offline   Reply With Quote
Old 06-12-2009, 06:34 PM   #16
Jeff @ TPE
Supporting Vendor
St. Jude Donor '06
Jeff @ TPE's Avatar
Good catch. I didnt put 2 and 2 together.
Old 06-12-2009, 07:01 PM   #17
ctsv510
CF Senior Member
this should be good. what's the eta on the cam install and retune?
ctsv510 is offline   Reply With Quote
Old 06-12-2009, 07:09 PM   #18
madmatt9471
CF Senior Member
No problem I was just wondering! I am looking forward to seeing you results - be careful
Thanks,Matt
__________________
Old 06-12-2009, 07:36 PM   #19
Z06wanted
CF Senior Member
Z06wanted's Avatar
I am interested in the end results also.
Z06wanted is offline   Reply With Quote
Old 06-12-2009, 08:31 PM   #20
tail_lights
CF Senior Member
tail_lights's Avatar
I was drooling over your car the other day! Mine is there getting some work done as well.
The dyno they have is known for low numbers. I know plenty of them say that but I saw it with my own eyes. A friends car put down 396 on a Mustang dyno literally right down the road and took it over and only made 398.
tail_lights is offline   Reply With Quote
Reload this Page My Kenne Bell results
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A&A Corvette Performance:Forced Induction Q&A thread Andy@AandACorvette C5 Forced Induction/Nitrous 819 03-20-2009 06:11 PM
DYNO TIME from Kenne Bell Twin Screw c5_from_jc C5 Forced Induction/Nitrous 251 09-25-2005 03:23 PM
What 1 mod would you do to go from SM2 to BP? Red5 Autocrossing & Roadracing 17 08-09-2005 08:59 PM
Had a long talk with Kenne Bell today. Andy@AandACorvette C5 Forced Induction/Nitrous 58 06-29-2005 04:01 PM
My Car is off to Kenne Bell for the Twin Screw c5_from_jc C5 Forced Induction/Nitrous 107 12-28-2004 08:23 PM
Finished ATI install...Dyno results...thanks Andy Blocktrdr C5 Forced Induction/Nitrous 18 02-20-2003 11:27 AM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
