Anyone Have Pics of Nitro Daves Fuel Cell Installed ?
Does anyone Have Pics of Nitro Daves Fuel Cell Installed ? I need to see a picture for a custom modification I need to make.
Thanks bro. I needed to add another fitting for my external carb low pressure pump. I will be running a ring and fogger which require different pumps.
Here is a pic of my setup Shane (Z06wanted) posted up earlier. I run the high pressure jets but need to replace them with low pressure. Please excuse the dirty engine bay.
You should be able to buy high pressure or low pressure jets for fogger and ring. As long as both are the same you just use one pump/regulator/pressure. I tune with fuel pressure on the big kit and then tune the small kit with the fuel jet. I hope this helps
I set the tank up to run separate pumps for each system. I plan to run 7psi hop switch to shut off the system if we don't get the required pressure.
So you run high pressure pills on the fogger ? How did it work out ?
Works fine. I do need a new regulator for my dedicated. It drops pressure at the first of the hit causing a lean spike. I replaced the diaphragm and its better but not 100%. I would rather have the low pressure but I screwed up when I ordered every thing and told them high pressure. My bad but it still works fine. Smaller jets stop up easier.
