Anyone want a transmission that will hold your F/I, nitrous power???
Old 04-10-2014, 06:33 PM
  #121
lsxvette
lsxvette's Avatar
car is heading to rick rkt56 this week for a 2013 z06 tr6060 swap ..let ya know how everything works out
Old 04-11-2014, 03:10 PM
  #122
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
You're in most excellent hands with Rick!
Old 07-27-2014, 06:03 PM
  #123
LedfootLarry
LedfootLarry's Avatar
With the C6 cradle, it sets the centreline
Of the wheel in the wheel well towards the
Back by 5/8". Any way of getting it back to
Center ?
I had a set of 28" Mickey drag radials on
the car at the dyno, and the passenger side
went through the inner fender, hit the bracket
and flipped it..... the screw dug into the tire to
the cord.
I am replacing it, and am going to run a
1/2 mile event with them, anyone else run into
this problem ?
Would changing A arms change the centreline ?
Old 07-27-2014, 08:52 PM
  #124
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Center ?
the cord.
this problem ?
Are you using the C5 or C6 a-arms? I thought the C5 arms were necessary for proper centering of the tire.
Old 07-27-2014, 09:50 PM
  #125
LedfootLarry
using C6 lower arms and C5 upper arms
Old 07-29-2014, 08:39 AM
  #126
BLOWNBLUEZ06
I will say in advance that I haven't personally done it, but a couple of forum members have reused their C5 arms and coilovers to keep the tire in its original place.
Old 07-29-2014, 10:53 PM
  #127
The Highlander
The Highlander's Avatar
Which A-arms? if you use C6 top A-arms it will put it farther back than using the stock c5 upper A-arms... I am using the lower C6 A-arms and the wheels are a tad back... and it looks sort of stupid.
Old 07-29-2014, 10:56 PM
  #128
The Highlander
The only way I see this getting to the correct position would be to lower the car substantially and when the camber is corrected in the alignment the wheel will go forward.
The other way is to use an eccentric type bolt on the rear.
Old 08-11-2014, 01:41 PM
  #129
yooper
Support Corvetteforum!
yooper's Avatar
Center ?
the cord.
this problem ?
Was this ever resolved?
Old 08-11-2014, 09:23 PM
  #130
BLOWNBLUEZ06
I'm missing how lowering the car moves anything forward. You would have to change the caster angle to move anything forward.
Old 08-11-2014, 09:38 PM
  #131
LedfootLarry
not yet, and not sure if I can.
Old 08-11-2014, 09:56 PM
  #132
The Highlander
Simple my friend....
Lower the car, it squats... (more camber), since the adjustment is the front leg of the a-arm, it will push the wheel a tad forward when you correct the alignment.
The new C7 has adjustment on both legs of the lower A-arm.
Old 03-09-2015, 08:31 AM
  #133
BLOWNBLUEZ06@RKT Performance
Supporting Vendor
BLOWNBLUEZ06@RKT Performance's Avatar
I will get the pics all updated. The server holding my pics changed.
Old 03-23-2015, 09:45 PM
  #134
BLOWNBLUEZ06
More exhaust pics uploaded to the CF server so they don't drop out any more.
Old 12-13-2015, 07:31 PM
  #135
Nosferatu333
Nosferatu333's Avatar
Thanks for this.
But what causes the need to mod the exhaust? Tranny,diff or cradle?
Thanks.
Old 12-14-2015, 10:02 AM
  #136
CamminC5
CamminC5's Avatar
St. Jude Donor '15-'16-'17-'18
The exhaust will not clear the outside of the diff. I cut 3" sections out of the x-pipe and added those pieces on the humps. No clearance issues. I cut the x-pipe before the hangers (to get the straightest pieces) and had to move the hangers, but that wasn't a big deal.
Old 12-14-2015, 03:01 PM
  #137
Nosferatu333
was trying to avoid hacking my corsa extremes.
any one know if we can boltup a c6 exhaust?? and avoid it?
To Anyone want a transmission that will hold your F/I, nitrous power???
Old 12-14-2015, 05:27 PM
  #138
Supporting Vendor
Originally Posted by Nosferatu333
Sure can, as long as you're willing to cut out the floor board and rebuild it to a flat surface.
It's not going to simply "bolt up" though. You'll have to re-engineer it some.
Old 12-14-2015, 05:46 PM
  #139
Nosferatu333
Doh!
Got a custom subwoofer enclosure in the well.
no can do.
Thanks!
Old 12-14-2015, 08:07 PM
  #140
CamminC5
CamminC5's Avatar
If you ever get another set of Corsas just reuse the hump section. Corsa uses that same section for all their exhaust.
Quick Reply: Anyone want a transmission that will hold your F/I, nitrous power???
