Tial 50mm bov which spring?
I'd like to replace the bosch bov that comes with the ECS paxton kit to a tial bov. It seems you have a choice of springs you can order it with, 7, 9, 11 and 12 psi. What would you suggest for a novi that will see about 15lbs of boost?
1 Post
look on their site they tell ya what ya need based off vacuum
http://www.tialmedia.com/documents/w3_tial_bov50_sp.pdf
-22 and -23 in/Hg Pink -12 Psi (-24 in/Hg )
-18 and -21 in/Hg Un-painted -11 Psi (-22 in/Hg )
-14 and -17 in/Hg White -9 Psi (-18 in/Hg )
-10 and -13 in/Hg Black -7 Psi (-14 in/Hg )
The valve needs to be open at idle-so you need a spring for that. If not you'll be heating up your intercooler for no reason, not to mention if it's not setup properly the impellar will 'touchdown" if the valve doesn't open soon enough.
FWIW, Vortech, Paxton and Procharger do not recomend the use of these valves.
Different strokes for different folks I guess.
I know, alot folks run it because it looks cool and sounds cool. When I was tuning a customer's car last year the IAT temps on steady cruise where in the 100's-120's when the ambient temps where in the 80's. The Vortech B57 and the Procharger "Big Red" are similar designs to the Tial but there's no need for "different springs". The valves are fully open at idle and cruise and close shut as soon as boost comes in.
I certainly do like the sound. It makes me smile.
Arun, I have always revered you as a pioneer, pushing the limits of the engines and supporting mods and respect your opinion. I read your previous posts about this and was reluctant to go the way of the BOV until Taylor from Dallas Performance, whom I also hold in high regard recommended one to me. At the time, I was in a bind and trying to solve my bypass valve trouble so I could get to the track, so Taylor welded the Tial flange on for me and I was on my way. I have had the opportunity to log my IAT's while cruising and have not yielded the same results you mention. With the Vortech race valve, on a 100° day, I have seen my IAT's get up to 115-118°, but never higher. After changing to the Tial, I noticed no rise in IAT's. I save all of my logs and date them, so when I get a chance, I will review them again and post up my findings.
Now, when you say "Race Valves" you mean the "small blue" one that comes with Andy's kits right? FWIW-that valve is way too small for a YSi, it only rated at 320cfm@8psi.
I run the "Big Red" on my car and I install it on most of the cars that I put together that run the "big blowers". With the valve this size at cruise you will never see IAT temps above ambient-so if it's 100 out, most likey you'll see temps around 90 while cruising. Another benefit to this is you'll keep heat opt of the intercooler as well.
Maybe I'm just splitting hairs, probably why my car is always in pieces but I guess I tend to "over engineer" everything.
Bro-there is nothing worng with your choice, it's just not what I would have picked that's all.
Andy told me I was on the edge with that little blue valve. I found out quickly I was over it.
Splitting hairs is sometimes what wins races! Sometimes it also causes war!
Not getting defensive here. Just trying to show respect while having an open discussion. I see folks get in ridiculous arguments on line because sometimes what is written is subject to interpretation and I just wanted to make sure you know where I'm comin from.
I'm also running a 50mm tial valve with no issues.
I switch from a Vortech Mondo valve, which is currently for sale here, and have no issues.
I'm not sure which spring I have in the tial. You do have to make sure the valve is open @ idle though.
I took my vacuum gauge and measured at which point the mondo opened then just made sure the tial did the same.
Verocious motorsports has them or can get them
Arun, I finally got to look at my logs before and after installing the Tial and wanted to let everyone know that you were right. My IAT's in the middle of August were in the low 90's and in early November they were low 120's. Definitely something to consider when purchasing a BOV.
Bobz,
I requested they send the lightest spring available as this was what we needed in order for it to release pressure at idle. I also use this spring on my turbo car.
