Worlds Fastest C5 Corvette???
Old 08-02-2008, 06:46 PM
DaWorm111
DaWorm111's Avatar
Default Worlds Fastest C5 Corvette???
Customer brought us his 04 C5 corvette in hopes to be the worlds fastest IRS corvette. Just thought some of you might like to see some pics of the build in progress. Setup is an LSX 408ci motor with ET 265 6 bolt per cylinder heads and twin 78mm ball bearing turbos Everything you see is fabricated here in house. This setup will be making 2000hp and still have cold blowing A/C!
Steven Fereday
Late Model Racecraft
713-466-9900
Latemodelracecraft.com
Old 08-02-2008, 07:06 PM
MPRTKLR
MPRTKLR's Avatar
Looks like it will be a monster. What exactly do you mean by world's fastest? 1/4 mile, standing mile, salt flats? Either way, best of luck
Old 08-02-2008, 07:07 PM
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
Very nice. Keep us informed on the progress.
IMXCITD
IMXCITD's Avatar
Wow!
Old 08-02-2008, 07:24 PM
DaWorm111
DaWorm111's Avatar
1/4 mile and maybe even standing mile
Old 08-02-2008, 08:18 PM
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Damn , subscribing to this thread for further results.
Old 08-02-2008, 09:44 PM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Old 08-02-2008, 10:40 PM
JET LEE
JET LEE's Avatar
Where you gonna put the radiator?
Does look like some nice work!
Old 08-02-2008, 10:43 PM
NemesisC5
NemesisC5's Avatar
I've seen your black F-Body with the big single that put down some serious times, been to your shop....enlighten the group here
Old 08-02-2008, 10:51 PM
MPRTKLR
MPRTKLR's Avatar
I would imagine it is going to be tough to setup the car to do both. By the time the car is complete, you'll probably need to run 7's @185 in the 1/4 to be the fastest/quickest (assuming Bill continues to progress with his new setup) and the standing mile I'm guessing the C5 record is around 220 or so. What trans are you going with? Definitely will be one helluva car. Best of luck with it
Old 08-02-2008, 11:52 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Nice work, I presume the radiator will be laid down flat.
Old 08-03-2008, 12:38 PM
FreddyG
FreddyG's Avatar
That's a tall order considering some of the cars that are out there, but if his car runs anywhere near what your car runs, it's entirely possible! Good Luck!
For you Guys that haven't seen Worm Boys car, it's SIIIIIICK!
Wormboy tearing it up...................
Old 08-03-2008, 01:19 PM
Brandon619
Brandon619's Avatar
7 seconds WOW! Great pictures of the build and 2000hp is amazing.
Old 08-03-2008, 03:51 PM
blu00rdstr
blu00rdstr's Avatar
Nice thick hose coming out of the fuel tank!
If I were to do my -8an fuel system again, I would bolt a pipe as armor inside the driver's side rocker panel, and run the fuel hose through that instead of the hot transmission tunnel.
Old 08-03-2008, 05:40 PM
Madddogg
Madddogg's Avatar
SICK.................I am thinking NASA when I see this beast.
Good luck with the quest.
Old 08-06-2008, 12:02 PM
DaWorm111
DaWorm111's Avatar
In the back!
Old 08-06-2008, 01:20 PM
cwk2
cwk2's Avatar
Daworm I sent you a pm.
To Worlds Fastest C5 Corvette???
Old 08-06-2008, 03:34 PM
LRD VDR
LRD VDR's Avatar
I got "WOOD"
Shahram
Old 08-06-2008, 08:17 PM
DaWorm111
DaWorm111's Avatar
Pm replied
Old 08-06-2008, 09:25 PM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Ohhhh! Man that is a beast
I will be looking forward to the finished product
Way to go on this build
Thanks,Matt
Quick Reply: Worlds Fastest C5 Corvette???
