help a nitrous noob out?
hey guys! project car 01 zo6 h/c/i full bolton
installing a nitrous outlet wet kit on my car along with LNC-2000 & micro storm controller have a couple questions
the micro storm has a window switch function so i need to know the following
tps signal wire location?
tps closes voltage & wot voltage?
best place to pick up tech signal?
For the tach signal you want pin #10 on the PCM (white wire).
For the TPS signal you want pin #1 on the TAC Modual (dk blue wire). You could also get the TPS signal at the TPS sensor at the T/B, but the TAC Modual is mounted to the PCM so it was easier to get them both there.
I did all my splices at the PCM since it looks cleaner. I think you can also get the tach signal from a coilpak, but nor sure which wire.
If I remember correctly, for the TPS there are two 5v signals a rising and falling. I'm pretty sure I used the rising one. It's been awhile since I messed with it so I may be wrong.
