Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A & A Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-21-2008, 02:03 AM   #1
jbusmc1986
CF Senior Member
St. Jude Donor '06
jbusmc1986's Avatar
Default why not? supercharger wastegate
So there I was the other night staring at the ceiling in bed, and this crazy idea came to my head to use a wastegate and a boost controller on a cenrtifugal setup, then bam, today I see this link. So my question is, why is nobody doing it? I would love to be able to go from 5 to 15 psi with no belt changes.
http://www.musclemustangfastfords.co...all/index.html
jbusmc1986 is offline   Reply With Quote
Old 06-21-2008, 03:27 AM   #2
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
You got me thinking for sure.
BLOWNBLUEZ06 is offline   Reply With Quote
Old 06-21-2008, 04:15 AM   #3
Ilovechevymusclecars
CF Senior Member
Wouldn't the tune somehow have to accomodate for the various boost levels? If this is possible, I want it!
Ilovechevymusclecars is offline   Reply With Quote
Old 06-21-2008, 04:52 AM   #4
1badvr4
CF Senior Member
1badvr4's Avatar
Send a message via AIM to 1badvr4
im thinking the only issue would be that intake temps....
if you were to go wot and spin the the blower to, lets say 20psi, and bleed off 10psi for the wanted 10psi charge, wouldnt the inlet temps be higher than if the blower were spinning to the wanted 10psi level? obviously the characteristics of the blower would change as you would need to be efficient at higher rpms(blower rpms, not motor) and then have to deal with the negative aspects of having a bigger blower than what you *really* need.
good forbid the spring get stuck and the motor get fed double the intake charge....kaboom!
1badvr4 is offline   Reply With Quote
Old 06-21-2008, 07:00 AM   #5
Warp Factor
CF Senior Member
Warp Factor's Avatar
It would work, it's just not very efficient.
The power used to drive the blower would be the same at low boost as it would at high boost, and the heat produced by the blower would be the same too.
More efficient would be a variable blower inlet restriction, or just changing restrictor plates, like some here do already.
Warp Factor is offline   Reply With Quote
Old 06-21-2008, 09:25 AM   #6
madmatt9471
CF Senior Member
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 1/4 10.34 @ 135 MPH - 701RWHP & 582RWTQ
Subscribing to read that post later!
I would go with more B@@ST too if I could have a controler
Thanks,Matt
__________________
madmatt9471 is offline   Reply With Quote
Old 06-21-2008, 10:30 AM   #7
jbusmc1986
CF Senior Member
St. Jude Donor '06
jbusmc1986's Avatar
If you will re-read the article, it states that when the wg was open, the temps were actually lower than normal at that psi. And on the efficiency note, the blower would be in its efficiency range all of the time, and would just not be bleeding off the boost at high boost settings, with a more linear torque curve.
Changing the restrictor plates, is a good way to do it, but I think this may be a better way. IMHO
Old 06-21-2008, 11:15 AM   #8
redcycle13
CF Senior Member
redcycle13's Avatar
I read that article a while back. Makes me want to try it, but I don't have the budget to try something like that and it be a waste. Any vette guys give it a try yet?
redcycle13 is offline   Reply With Quote
Old 06-21-2008, 11:16 AM   #9
NemesisC5
Over The Edge
NemesisC5's Avatar
Send a message via AIM to NemesisC5 Send a message via MSN to NemesisC5 Send a message via Yahoo to NemesisC5
NemesisC5 is online now   Reply With Quote
Old 06-21-2008, 12:27 PM   #10
jbusmc1986
CF Senior Member
St. Jude Donor '06
jbusmc1986's Avatar
I am sure that one of the nuts here is willing to try it out, I would do it, but I am in afghanistan till this fall, and don't even have the blower yet, only 3 payments left to andy.
Old 06-21-2008, 12:55 PM   #11
ajg1915
CF Senior Member
St. Jude Donor '08
ajg1915's Avatar
Just really need A&A or ECS to make a prototype charge tube with wastegate.
I've been looking at this option or a single turbo. I don't really want to have to run around in high HP mode all of the time. Looking for some type of compromise.
When I get to this stage of my car build, hopefully somebody will have something avaialble.
ajg1915 is offline   Reply With Quote
Old 06-21-2008, 01:49 PM   #12
Slowhawk
Premium Supporting Vendor
It's not efficient.Already tried it.
Your forgetting the important feature of the supercharger, you can control boost level with your foot.
Slowhawk is offline   Reply With Quote
Old 06-21-2008, 01:55 PM   #13
ajg1915
CF Senior Member
St. Jude Donor '08
ajg1915's Avatar
Yes and No. It's more RPM related, so the more gas you give the more boost you get.
If you want the best of both worlds you would want the wastegate.
Old 06-21-2008, 02:51 PM   #14
jbusmc1986
CF Senior Member
St. Jude Donor '06
jbusmc1986's Avatar
what is not efficient? Please elaborate, how was the car setup? When running the smaller pulley, to make more boost you would achieve that 7 or whatever psi that you desire much faster than on a conventional setup, thus giving you more power under the curve.
Old 06-21-2008, 03:09 PM   #15
blu00rdstr
CF Senior Member
blu00rdstr's Avatar
Send a message via Yahoo to blu00rdstr
Wastegates on superchargers is a pretty old concept, and easy to implement. I'm sure lots of experiments were done on this already.
__________________
  • '05 Z51 Silver C6 Coupe - T1 swaybars
  • '00 Blue C5 vert (wrecked) - Forged LS3, 660rwhp/650rwtq (w/slipping converter), FLP L5 trans, Vigilante converter, Nitto R2 tires, dual pumps 8an lines, A&A D1SC FMIC 8rib, SD 2bar tune and Cam by Rick @ Synergy.
blu00rdstr is offline   Reply With Quote
Old 06-21-2008, 03:27 PM   #16
jbusmc1986
CF Senior Member
St. Jude Donor '06
jbusmc1986's Avatar
Quote:
what I am curious of though, is why is it never done? I haven't found a downside to it yet. I do know that it is an old concept, because I forget where, but I saw the original patent for the first one in a magazine somewhere, and it said turbo/supercharger regulator, or something to that effect.
Old 06-21-2008, 04:07 PM   #17
blu00rdstr
CF Senior Member
blu00rdstr's Avatar
Maybe because a restrictor plate is simpler, Occam's Razor.
__________________
Old 06-21-2008, 04:26 PM   #18
ajg1915
CF Senior Member
St. Jude Donor '08
ajg1915's Avatar
Pop off valves were used on the manifolds, not wastegates.
Old 06-21-2008, 04:26 PM   #19
jbusmc1986
CF Senior Member
St. Jude Donor '06
jbusmc1986's Avatar
A restrictor plate would be easier initially, but once this was finished, You could up the boost from the drivers seat, with absolutely no removing of anything, or stopping and pulling out your screwdriver. I think that if no one has any better info on this I will try it this fall/winter when I get back to the US and install my blower and things.
Old 06-21-2008, 07:31 PM   #20
chriswtx
CF Senior Member
chriswtx's Avatar
Send a message via AIM to chriswtx
I had been waiting to post up until I was completely finished and had my high rpm miss figured out. I did this a few months back. Running a 2bar SD tune. Added a 5psi waste gate to the intake charge tube and a Greedy Profec B boost controller for waste gate control..Works like a charm. Low boost is set at 13-14psi, high boost is set to max, whatever the blower pulley is, 18-20psi. With a push of a button you can go from 14psi to 18psi. No pulley changes or ristrictor plates needed... Low boost made 640rwhp, high boost was 720rwhp at 5700rpm..Haven't dynoed over 5700rpm yet..Still working on that problem..
Couple of pics..
__________________
2004 C5 Silver M6 Tigershark,Forged 346,Diamond pistons,eagle rods,Kooks 1 7/8",226/232 .586/.591 116LSA,comp RRs,PRC LS6 heads,Corsa,ECS Paxton Novi 2000 832rwhp/691rwtq
1991 C4 6sp, 400block,3.48stroke=379ci, 6.125" rods,Brodix T1s, 236/236 .587, tunnel ram, B&B 3", 4.11's, 440rwhp, 405rwtq
Factory Five GTM in progress
chriswtx is offline   Reply With Quote
Reload this Page why not? supercharger wastegate
Tags
aa, c5, corvette, ecs, photos, shim, spring, supercharger, superchargers, thickness, wastegate, wastegates
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Supercharged Corvette. Why not an option 2000 green hornet C6 Corvette General Discussion 15 07-31-2005 01:36 AM
Twin Turbo's or KB Boost? Vince99FRC C5 Forced Induction/Nitrous 70 07-13-2005 03:45 AM
They say it can't be done but I'm going to do it! Electric Forced-Induction! BIG JIM 54 C4 Forced Induction/Nitrous 35 12-02-2003 03:57 PM
Supercharger? blurredvision C4 Tech/Performance 27 07-25-2003 11:47 AM
Procharger, Vortech....I'm gonna buy next week! Irishpilot03 C4 Forced Induction/Nitrous 58 05-26-2003 02:45 AM
Supercharger vs Turbocharger and why.... ImAgE C5 Forced Induction/Nitrous 138 09-07-2002 12:59 AM
Newie Question-Difference between a supercharger and a turbo charger?? wanta81shark C3 Tech/Performance 17 01-10-2002 12:51 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
