Krank Vent PCV System: Anybody Care To Share Their Opinions?
I'm re-plumbing my PCV system and seriously looking to pull the trigger on the KrankVent check valve PCV system. Very simple system with only two check valves that are of a patented design. I spoke with the vendor/designer and he told me the system works extremely well, so good in fact that you will not need a catch can to trap oil unless your race and your sanctioning organization requires one. The system builds a fairly high amount of CC vacuum, even to the point in some cases of makes a whistling noise pulling air through your crankcase seal (this point concerns me, but he said he is designing a variable vacuum bleed-off valve for the rew applications that may need one...just not finished yet). He also told me the system is used in many racing cars and is instrumental in ring seal where low tension rings are used. I don't plan on racing my stock bottom end but I would appreciate less oil in my intake and any efficiencies (power) gained by using this system.
The instructions on the website state that your engine must be sealed without breathers to realize the positive effects of better ring seal (more HP/TQ). Below I posted a link to a closed thread for reference. If you do a Google on KrankVent you can pull up the website, I know they are not a sponser so I didn't want to violate forum rules (I believe that's the rule). Any feedback from those who have used, or are using this system now will be appreciated
http://forums.corvetteforum.com/show....php?t=1559086
http://ls1tech.com/forums/showthread.php?t=734113
Twin Turbo Coupe
I ran them for a while and found that they pulled a a lot of oil into the intake even with a catch can....this was due to the large amount of vacuum they allowed to be pulled. I made a vacuum relief valve which helped reduce the amout of oil ingested.
I have since them installed a mechanical vacuum pump which has worked the best so far. It was really interesting to see the amount blow by and condensation being captured.
If you are interested in a used set, let me know
It made my car squeal loudly as it sucked air thru the rear main seal. Thought I had a pulley bearing failure.
I don't see how this will do anything for oil ingestion.
The idea is good, but the squeal is a deal breaker.
You need to control how much vacuum is in the crankcase by using a relief valve like the Moroso PN# 22637
I don't get it.
Under WOT, there will be boost pressure in the intake and pressure in the crankcase from ring blowby. That pressurized oil mist has to go somewhere. If a hose carries it to your aircleaner, it's going down your intake, condensing as it hits surfaces, and getting pushed along the floor into the last runner (#7).
I call that you don't need a catch can.
I don't get it.
Received 1,817 Likes
I don't get it.
And besides, if the goal is to pull a vacuum in the crankcase, there won't be any vacuum at high throttle openings, which is when you'd want it most.
Twin Turbo Coupe
Never popped a dipstick....just wanting a clean intake and if I can accomplish some improved ring seal at the same time it would be icing on the cake. The KrankVents sound good but I wanted to hear real world feedback. Mech EVAC pump is the best, but I do not know any vendors offering kits for centri-supercharged applications. I thought the Mech EVAC pumps mount where your AC unit is
Where did you mount your EVAC pump?
I had one on my harley, and it worked good for a V-twin. I'm not sure about a V-8. The way they work is you seal the motor tight (Means no breather and no PCV to the intake and no gasket leaks), when the pistons goes down, the crankcase makes pressure and the valve releases and lets it out. When the piston goes back up, the valve closes and the crankcase makes a negative pressure.
So on a V-8 where there is always pistons going down with some are going up, I am not sure how this would work.
Also, since it is vented to the atmosphere, you will need a filter on the end of the Krank Vent, and it will need to be cleaned often or it will soak up with oil and dirt.
But this is why they say you don't need a catch can. Because it's not plumbed back into the intake tract. And your cylinders will stay cleaner. But you may have a mess at the end of the Krank Vent. Oil vapers has to go somewheres.
Here's some old posts that talk a bit about the Krank Vent. It seems to work in principle, but sounds like it might have to be fine tuned for our setups. Good Luck Scottie!
http://forums.corvetteforum.com/show...ght=krank+vent
http://forums.corvetteforum.com/show...ht=vacuum+pump
OEM PCVs don't seal. Nothing like heavy boost backing into your block instead of the intake. I replaced mine with a Krank Vent and couldn't be happier. I also have a hose running from my oil fill to my air filter for any blow-by. People putting PCVs there can get excessive vacuum (i.e., gaskets unseating, whistle noises).
Also have a catch can behind the Krank Vent, which works well.
I'm curious as to where the system draws in it's filtered make up air....and I second that any excess vacuum enough to pull ait past a seal is also pulling dust & dirt directly into the crankcase....which is never good. A Reher Morrison or Moroso vac relief valve w/a filter incorporated will cure that problem.
Thanks!
An Idea, Opinions Please
I think this might work. Cap off all ports other than ones used. LS6 valley port through check valve (to block boost) to one leg a "T" in front of CC. Driver side valve cover port (factory PCV line) into back of CC. From "T" in front of CC to Check valve then on to intake side of Supercharger or Turbo. The system will either "choose" the strongest vacuum (or maybe combined but I think the check valves will only allow one line to pull) source (intake manifold under deceleration/supercharger-turbo under boost) to pull crankcase vapors through CC. Fresh air is introduced into the system through a breather on oil filler cap. The check valves can either be the McMaster Carr units or the Krank Vent units.
It seems to me that with this system you will always have vacuum pulling fresh air into the engine that should evacuate harmful oil vapors collecting into the CC before it gets re-introduced into your engine. If anybody sees that this will not work please punch some holes in it
1 Post
St. Jude Donor '09-'10
Scotty, your diagram looks almost identical to the way Tracy wants mine setup. Only difference that I can see is the way the CC is plumbed, but that will also depend on the type of can. On the M. Norris can I have coming, Tracy wants me to run the hose connected to the bottom of the T (hooked to your valley port in the diagram) to the bottom fitting on the CC and run the hose from the top CC fitting to the T where the valley port hose use to be....(hope I didn;t screw that up?)
We REALLY gotta straighten this out once and for all for F.I. cars. There MUST be one RIGHT way to achieve the proper goals. Sure am glad you're taking this challenge on.
