How To install 2 bar map sensor???
Old 05-23-2008, 10:45 AM
95BlueBomber
95BlueBomber's Avatar
Default How To install 2 bar map sensor???
Can some clarify for me the process of this. Do you have to plug the hole for the stock MAP and run a vacuum line to this new sensor? Then do you have to change the wiring up to accomodate the new sensor. I was going to order a 2 bar sensor but it appears that the sensor for the Meth kit is 2 bar so it should work right?
95BlueBomber
Also to clarify I have an extra meth kit Map sensor
Old 05-23-2008, 11:04 AM
RED99
RED99's Avatar
If you have the correct MAP, it should replace the OEM MAP you have and plug right into that OEM harness. You will have to pull off the rubber boot and swap it out. But its plug n play.
The Meth MAP will plug into a manifold port and will have it's own wiring.
Old 05-23-2008, 11:56 AM
95BlueBomber
where can I obtain the correct MAP sensor and does anyone have the part number?
Old 05-23-2008, 12:15 PM
AVB
AVB's Avatar
Are you using the 2bar for tuning purposes or is this specifically for alky?
If for tuning, there is a plug ad play 2 bar but you will need a tune which is made for it.
Arnel
Old 05-23-2008, 12:19 PM
AVB
AVB's Avatar
Allright, it sounds like you should keep the one you have in place and just add the 2bar for meth.
Do you have an electronic boost gauge? Some come with a map sensor or outputs and provide everything you need, voltage wise.
Arnel
Old 05-23-2008, 01:10 PM
95BlueBomber
Arnel its not for meth... its for tuning
Old 05-23-2008, 01:11 PM
95BlueBomber
I am wanting to go to a 2bar SD OS
Old 05-23-2008, 02:23 PM
Shinobi'sZ
Shinobi'sZ's Avatar
LS1speed sells a pig tail that plugs into the stock connector for the stock map wiring harness. Just unplug the connector from the stock map and plug it into the new connector (pig tail) then plug in the other end to the new map. You will need to run a new vacuum line to the new map and plug it in. This is the way I did it with the 3bar map. You can leave the stock map in place...you are simply relocating the new map off of the intake manifold to an alternate location.
or
I believe GM sells a drop in replacement (but don't know for sure) that is a 2bar OEM part for the Cobalt. But as I stated I am not sure that it will plug directly into the back of the LSx intake.
The remote option is very easy...probalby the easiest mod I have ever done.
Old 05-23-2008, 02:37 PM
AVB
AVB's Avatar
For up to 15 lbs boost - plug & play:
2.5bar:GM P/N: 12580698 AC Delco: 213-1631
http://forum.efilive.com/showthread....light=12580698
Kevin: That's looking pretty complete there buddy..
Old 05-23-2008, 02:43 PM
Shinobi'sZ
Shinobi'sZ's Avatar
Good reference (link) you provided Arnel.
When is the next get together I am tired of just driving my car to work on occasion and giving people rides.
I was thinking Vette Magic would be good, but if the weather (in June) is 100*+ out I have no desire to go to the strip and hammer on my car.
Actually this weekend would have been perfect for a track day at Sacto.
Old 05-23-2008, 03:03 PM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
When I used the 2-bar sensor, I just plugged it in, converted to new OS and began tuning. I used the 2-bar sensor from the Cobalt part #12569241
Old 05-23-2008, 03:06 PM
AVB
AVB's Avatar
Well the new clutch is in so I will probably go. There are a few cruises in the norcal section posted. I believe even a Yosemite one. Just let me know and I'll be sure to join ya.
Arnel
To How To install 2 bar map sensor???
Quick Reply: How To install 2 bar map sensor???
