a&a corvette pulleys
anybody running their 6 rib 3.4 pulley? i've got one coming in the mail after finishing my kooks lt install and just wondering what boost i can expect, stock heads, cam and intake , but alky kit, boost a pump and now 1 7/8 headers with 3 o/f x-pipe should open her up a little and going from a 3.6 to the 3.4 should shake things up a bit
Received 1,762 Likes
Yea I have the A&A 6 rib 3.4" pulley on a T-Trim head unit making 14 psi. No belt slip at all.
I got belt slip when I went to a smaller than 3.4" pulley from Vortech as Andy doesnt make one smaller than his 3.4".
No meth running 17 degrees timing
Dropping from a 3.6 to a 3.4" will net you 2-3 more psi.
nice, good to hear nothing but good things, i figured there was a reason thats the smallest 6 rib they make, like i said, it will be next wed. and i hope so see 10 psi
you can move down to a 3.2 from vortech or reichardracing but those pulleys are hard to come by...Only thing is the vortech pulleys have no shoulders ...which should not be a problem if all is set up correctly
With an S-trim + Andy's kit don't go below a 3.0" pulley with the 6-rib.
Ran a 3.0" for a couple of years. Tried a 2.8" and started slipping.
Long ago, when I switched from 3.6 to 3.4 pulley on 6-rib; Gained 37 RWHP!
Those were the days.....
