The Beginning of the Custom Front Mount GT47-88
The break down Begins:
As some of you know I had a Front mount GT42R. But now im starting a new build with a GT47-88 front mount turbo. Im at my begin stages of getting everything together. There will be alot of new things im doing this time around. By this weekend I should have the drivetrain and engine back in. I posted the header picture on the inside to show the custom quality work we do. The turbo fabricating wont happen for a few weeks. Here are some pictures
Holy custom setup batman! Man you are going to be loving those turbos .
ouch
you must love workin on your back or somethin....got a good chiropractor???....you probably will have by the time this set up of yours is done ...you got ballz or your nuts!!
best of luck with your new build !!!!!!!!!!!!!!
WOW! You do not mess around at all!
That is going to be awesome!
How many MM's will the Turbo's be?
Thanks,Matt
Thanks,Matt
Im changing my setup because the GT42r was to small for my 408. Plus now I can try and hit my 1500hp goal O and about me doing this on my back im so use to it after doing my GT42r setup that this is going to be nothing. But this will be my last time doing it with out a lift.
HI guys,
Well I just got my driveshaft back from ECS which is amazing! Also I made solid motor mounts. I will be putting together the drivetrain ths weekend. here are a few pics
O yeah and here is the MONSTER GT47-88 Turbo
