Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A & A Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-11-2007, 01:44 PM   #1
CrazyChris
CF Senior Member
Default 408 + S91 Hits the Dyno
New setup ran flawlessly on the dyno. Made 18 back to back pulls and didn't use a drop of oil or push a drop of water. Ran out of WG spring or we would have gone higher.
722whp 653wtq 14psi pump gas
908whp 771wtq 19psi good gas
Dyno was a Superflow AutoDyn 30 with eddy current load cell. This dyno is notorious for low readouts. On the graph I included my baseline 408 run without the turbo kit installed. 390whp 367wtq!
Video of the pulls. Turbo really comes alive at the end.
http://videos.streetfire.net/video/7...0100a2a529.htm
__________________
2000 Corvette MN6
LME 408ci, custom 417Motorsports single turbo kit, PT88mm, HPT 3Bar SD, PP heads, vic jr. intake
CrazyChris is offline   Reply With Quote
Old 12-11-2007, 01:56 PM   #2
Jeff @ TPE
Supporting Vendor
St. Jude Donor '06 & '12
Jeff @ TPE's Avatar
Send a message via AIM to Jeff @ TPE
Hey Chris,
This gives me hope.. I dont know if your friends told you, but it looks like 417 Motorsports will be building my single 91mm on my new car..
Jeff @ TPE is offline   Reply With Quote
Old 12-11-2007, 02:08 PM   #3
JZ 97 SS 1500
CF Senior Member
Nicely done Chris. Looks like our S91 is doing the deed quite wheel. Crank her up to 24-26psi and she what she does, just make sure the heads are nice and tight.
Also with a Superflow your down 10-15% to a Dynojet depending on what they inputed for your variables. On a Dynojet your into the 1000-1075rwhp range.
__________________
Forced Inductions.com
JZ 97 SS 1500 is offline   Reply With Quote
Old 12-11-2007, 02:23 PM   #4
CrazyChris
CF Senior Member
Quote:
Originally Posted by AMERICAN_HP View Post
Hey Chris,
Awesome Jeff! Definitely have the potential for insane power.
I tried for 21psi but couldn't get any more out of the controller with a .6bar spring in the gate.
The L19 head studs are doing their job. The S91 is just starting to scream at 16psi. The guys running the dyno had the load set waayyyy to low, it took forever to get it spooled. It spools faster on the street than it did on the dyno this time. Thanks for an awesome turbo
Old 12-11-2007, 02:40 PM   #5
CraZee ZO6
CF Senior Member
CraZee ZO6's Avatar
Send a message via AIM to CraZee ZO6
that is awesome! great setup man badass!
417 motorsports should produce these kits now that they made them.
__________________
2003 ZO6
Built by Vette Doctors.
RX500 (old setup)
H/C 346 LS6 Trickflow 215 heads w/ comp 921 duals
Vette Doctor Custom Spec COMP XER SICK STICK
Harland Sharp 1.7 RR's TPIS LT's w/dr gas X pipe, GHL exhaust Stock LS6 Intake, TB and pullies.
485rwhp 427rwtq SAE
New setup.. RX427TT
427 6 bolt ERL sleeved LS6 setup for turbos MAST Motorsport LXR, Callies Dragonslayer,Callies I beam rods, Weisco Pistons, Lunati lifters, Comp cam.
CraZee ZO6 is offline   Reply With Quote
Old 12-11-2007, 03:00 PM   #6
Jeff @ TPE
Supporting Vendor
Jeff @ TPE's Avatar
They want to, but the clearences are sooo tight, it would be near impossible. When I was talking to them, they were telling me there is spots where theres less than 1/4" clearence on the pipes. So little, that if the motormounts are bad, it can make things hit.
Theres no way they can sell this as a kit setup.
Old 12-11-2007, 03:04 PM   #7
Vince99FRC
CF Senior Member
Vince99FRC's Avatar
Send a message via AIM to Vince99FRC Send a message via MSN to Vince99FRC Send a message via Yahoo to Vince99FRC
Very impressive!!
__________________
1999 Chevy Corvette FRC
SW408ci, AFR225, 8.5:1
TTi X Twin Turbo kit, .82 A/R
Tex Twin Exoskel
RevXtreme Catch Can Setup
796rwhp@12.5lbs
Vince99FRC is offline   Reply With Quote
Old 12-11-2007, 03:38 PM   #8
Nick@Newtech
Premium Supporting Vendor
Nick@Newtech's Avatar
Send a message via AIM to Nick@Newtech
Quote:
The whole time I watched the video I was like gee that sure seems like it doesnt have much load on it. How does the load affect dyno numbers?
Nick@Newtech is offline   Reply With Quote
Old 12-11-2007, 03:49 PM   #9
Shinobi'sZ
CF Senior Member
Shinobi'sZ's Avatar
Talk about a peak...it almost looks like my biceps peak.
That should be a great setup for the strip!
Your baseline dyno numbers don't look that far off for a low compression 408cid. Most stock C6 Z06s with high compression 427s are right around 450 whp out of the box.
Shinobi'sZ is offline   Reply With Quote
Old 12-11-2007, 04:32 PM   #10
CraZee ZO6
CF Senior Member
CraZee ZO6's Avatar
no load on the dyno will make any turbo setup look like peak setup.
Old 12-11-2007, 04:35 PM   #11
CrazyChris
CF Senior Member
Quote:
I couldn't build much boost because of the the no load and that's why the graph comes on so strong up top. Here is the break down per rpm:
3k 0psi
4k 5psi
5k 13psi
6k 18psi
Give me that 18psi or even 13psi at 4k rpm and the graph will look completely different. Peak numbers would be close I'm sure. Not that it matters. I am after the time slip
Old 12-11-2007, 04:42 PM   #12
AVB
CF Senior Member
AVB's Avatar
Send a message via Yahoo to AVB
Nice setup and excellent results!
AVB is offline   Reply With Quote
Old 12-11-2007, 04:50 PM   #13
Robert@Advanced Dyno
CF Senior Member
Send a message via AIM to Robert@Advanced Dyno
Sick man! I had no idea you were building this!!!!
Robert@Advanced Dyno is offline   Reply With Quote
Old 12-11-2007, 05:26 PM   #14
Shinobi'sZ
CF Senior Member
Shinobi'sZ's Avatar
I have ran my setup on both a load an non load and the graph doesn't look a whole lot different....about 200 rpm difference but the result of using a load dyno was that it developed a little more tq and a little less peak hp.
So I am familiar with how it works....if this was on a load dyno the graph would not shift to the left more then a 2-300 rpms.
This observation should not be misinterpretted as anything other then a fact.
What I am seeing more then anything is a setup that works very well with minimum back pressure and that allows the power to pull up to max redline. That's why I said it looks like it will be a great setup for the strip....like a lot of big single turbos are.
Most people running these aren't to worried about launching under 4K rpms...so they are spooled up and into the turbo's sweet spot right out of the gate....good think about having a v8 is that there is plenty of power off of boost for normal driving...if there is such a thing as normal driving when you have a turbo'd v8.
Old 12-11-2007, 05:32 PM   #15
Z06PSI
CF Senior Member
Nice numbers.
Looks like you have the same elbow and intake setup I have for sale.
Z06PSI is offline   Reply With Quote
Old 12-11-2007, 05:33 PM   #16
CrazyChris
CF Senior Member
So 200-300 rpm is all you saw. Do you recall how much load was being applied?
Launching off the 2-step is a must at the track.
Old 12-11-2007, 05:40 PM   #17
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Wow you really got one impressive setup and should be a blast on the strip
peter pan is offline   Reply With Quote
Old 12-11-2007, 06:01 PM   #18
Mitch.Shea
CF Senior Member
Mitch.Shea's Avatar
nice numbers! when do you plan on taking it to the track? looking forward to more vids! shoot me a pm if you have any more footage.
Mitch.Shea is offline   Reply With Quote
Old 12-11-2007, 07:00 PM   #19
Jeff @ TPE
Supporting Vendor
Jeff @ TPE's Avatar
Hey Chris,
I'm on the phone with Bryan over at LME right now.. He said GREAT JOB.. He also said to turn the damn thing up.
Old 12-11-2007, 07:33 PM   #20
mdhmi
CF Senior Member
mdhmi's Avatar
Send a message via AIM to mdhmi Send a message via Yahoo to mdhmi
Very nicely done. Any pics of the turbo kit? What type of IC?
mdhmi is offline   Reply With Quote
Reload this Page 408 + S91 Hits the Dyno
Tags
30, 408, area, autodyn, bay, build, corvetteforum, crazychris, dyno, for, price, s91, sale, superflow, turbo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
