Relocation Power Steering Reservoir
I need to relocate the power steering reservoir. I am installing a FAST intake and 90MM throttle body. The throttle body needs to be rotated 180*, putting the motor on the drivers side. Any thoughts as to where to mount the reservoir?
Former Vendor
St. Jude Donor '06 & '12
You dont need to relocate the P/S resv with a FAST intake and 90mm TB.
I'm running a FATS 90 with an LS2 TB, and the P/S resv is in the stock location.
If you are running an LS2 TB, you run it with the motor on the passenger side.
I have an A&A bracket with a D1SC the LS2 TB motor will not fit in the standard config with the motor on the passenger side. The TB motor interferes with the bracket.
One person emailed his solution, which is mounting it just forward of the windsheild washer tank. The other route looks to be that I could mount the bracket in the same mounting holes using 2, 3" inch round spacers, moving the tank forward of the motor on the T/B.
Thank You Glenn
FourG63 97GST (06-01-2023)
If I remember correctly when I put on the BBK throttle body it also needed to have the PS reservoir relocated with spacers supplied by BBK in the Kit. They may give them to you or let you know their dimensions.
Matter of fact I still have that 90mm relocation bracket. I dont use it because I built a bracket and mounted mine to the bolt that goes through the tensioner. I will give it to ya for whatever shipping is if interested let me know.
Thank You Again, Glenn
I have found 2" spacers with 120mm M10X1.5 bolts and notching the bracket works fine.
St. Jude Donor '17-'18-'19
Relocating it to the other side is just not working. I would like it to disappear up into a fender or something but in front of the washer tank is another idea and it keep is above the pump.
Sorry I can not tell you. I have cleaned out my email and I no longer have that info.
I am quite happy with 2" spacers 3/4" dia. and 120 mm long bolts and a new peice of hose that is prebent. I went to the local CAP and picked out a preformed hose.
This works well. The other thing is Tyson made a generous offer with a bracket for relocation.
Last edited by glennd; 11-05-2017 at 03:25 PM. Reason: updated lengths of bolts and spacers
