Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A & A Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-06-2007, 11:50 PM   #1
Corvette-Chris
CF Senior Member
St. Jude Donor '08
2002 Chevrolet Corvette
Corvette-Chris's Avatar
Location: NW Louisiana (Cheap, Fast, Reliable) Pick two, because your car cant be all three.
Default Help with fuel pump questions
I am putting AFR heads on my already cammed and sprayed car. It should be right around 550 RWHP but I may push it to 600 RWHP but no more than that. I rarely use the nitrous but I like to have it if I ever want to use it. Can I upgrade the fuel pump and run a boost a pump? Is that the best way? I dont want a stand-alone or anything of that nature and I dont want to spend outrageous amounts of money. Any imput is apprecaited.
Chris
__________________
-LME Built 347
-APS Twin Turbo
-Dallas Performance Turbo Cam
-AlkyControl Methanol Injection
-317 heads, LS2 Intake/TB
-Assembled by Me
-Dallas Performance Tuned
-768 RWHP & 690 RWTQ at 13.8 psi
Corvette-Chris is offline   Reply With Quote
Old 11-07-2007, 12:16 AM   #2
Mr. Big
CF Senior Member
St. Jude Donor '07-'08
Mr. Big's Avatar
Racetronix pump and kit along with a boost a pump should do the trick
Mr. Big is offline   Reply With Quote
Old 11-07-2007, 12:51 AM   #3
FactoryRaceCar
Spray n Pray OR do Turbos
St. Jude Donor '05-'06-'07-'08-'09
Support Corvetteforum!
FactoryRaceCar's Avatar
Quote:
LPE pump or Racetronix (I had better luck with LPE), Racetronix wiring harness and KB BAP or MSD BAP will do the tricks. Dont forget appropriate injectors and TR6 plugs.
FactoryRaceCar is offline   Reply With Quote
Old 11-07-2007, 09:28 AM   #4
Beer99C5@FastbirdPerf.com
CF Senior Member
St. Jude Donor '08
Beer99C5@FastbirdPerf.com's Avatar
Send a message via ICQ to Beer99C5@FastbirdPerf.com Send a message via Yahoo to Beer99C5@FastbirdPerf.com
I have a H/C Sprayed car and log fuel pressure. Currently with a Racetronics and a hotwire kit (just upgraded wiring, no BAP), the wet kit drops to low 40 PSI but recovers. BAP will probably be my next upgrade. I am 417 NA and spraying to 525. The dry kit does not reflect as much fuel pressure drop than the wet when activated.
Beer99C5@FastbirdPerf.com is offline   Reply With Quote
Old 11-07-2007, 11:04 AM   #5
Corvette-Chris
CF Senior Member
St. Jude Donor '08
Quote:
Will the Walbro GSS340 pump work fine?
Old 11-07-2007, 09:07 PM   #6
Racetronix
Premium Supporting Vendor
Racetronix's Avatar
Quote:
No.
Racetronix is offline   Reply With Quote
Old 11-07-2007, 11:36 PM   #7
Corvette-Chris
CF Senior Member
St. Jude Donor '08
Quote:
Originally Posted by Racetronix View Post
No.
Thats funny.....Others have told me it will work just fine
Old 11-07-2007, 11:56 PM   #8
Racetronix
Racetronix's Avatar
Others?
What do they consider fine?
The factory and RX/LPE pump has unique features so it functions with the factory bucket. A GSS340 will not do that.
Old 11-08-2007, 01:11 AM   #9
Corvette-Chris
CF Senior Member
St. Jude Donor '08
Well what pump are people refering to when they say they have a Walbro 255 LPH, with a BAP and a Racetronics harness? They said it can be found for under $100 so I figured that was the one
Old 11-08-2007, 02:13 AM   #10
Racetronix
Racetronix's Avatar
The function of the jet pump is described in our web ad:
http://www.racetronix.com/RX-C5-FPK-2.html
There are always those people who are willing to cut corners in order to save a few $. Will a GSS340 work? YES, if you modify / disable the factory system. Will it work properly? NO.
The RX/LPE GRJ420 included with our C5 kit is a 255LPH pump when rated at 43.5PSI like all the other 34x series pumps.
Old 11-08-2007, 12:35 PM   #11
Corvette-Chris
CF Senior Member
St. Jude Donor '08
No.
Just talked to Lingenfelter, They said it is a direct replacement
Old 11-08-2007, 08:25 PM   #12
Racetronix
Racetronix's Avatar
Who did you speak with at LPE? The GSS34x series pumps are not a direct replacement for the factory C5 pump.
C5
http://www.lingenfelter.com/store/ln0065.html
C4
http://www.lingenfelter.com/store/rx-c44-fpa-b.html
Old 11-08-2007, 09:24 PM   #13
Corvette-Chris
CF Senior Member
St. Jude Donor '08
^ Tim is who i talked to. he said the GSS340 is the same pump that is in their C5 kit but without the plastic surround. He said they sell it seperatly incase people want to use it in other applications.
Old 11-08-2007, 10:08 PM   #14
Racetronix
Racetronix's Avatar
Well Tim must be new.
The pump in their C5 kit is a GRJ420 which has the jet pump at the bottom and they do not sell it by itself. If you doubt this call and speak with Jason the engineer there.
http://www.racetronix.com/Fuel_Pump_Ident.html
We will contact Tim to advise him of his error.
Old 11-09-2007, 09:14 AM   #15
Corvette-Chris
CF Senior Member
St. Jude Donor '08
It was bad info. My mistake, I was just repeating what I was told.
Old 11-09-2007, 09:23 AM   #16
jhaines
Supporting Vendor
jhaines's Avatar
Default GSS340 in a C5
I think Tim in our sales department may have already been in touch with you (Chris) regarding this. He was confused on the part numbers. The GSS340 Walbro/TI Auto pump is not a drop in replacement for the C5 Corvette fuel pump. It does not have the inlet side jet pump (venturi pump) required to keep the Corvette canister full. It is also not the correct inlet dimensions to fit in the module without module modifications.
The GRJ420 is our high flow replacement pump for the C5 Corvette applications. It is the same pump Racetronix includes in the C5 pump kits they sell as well.
The GRJ420 pump is only sold as a complete assembly with the plastic module.
BTW - sorry for the confusion any of this caused. Also to answer the original question, I would recommend (like others have said) the high flow pump module and then a voltage booster for when you trigger the nitrous. We normally use and sell the Kenny Bell Boost-A-Pump (BAP) and have had very good durability with the BAP and the pumps under the elevated voltages.
Jason Haines
Project Director
Lingenfelter Performance Engineering
jhaines is offline   Reply With Quote
Old 11-09-2007, 06:39 PM   #17
Corvette-Chris
CF Senior Member
St. Jude Donor '08
Hey Jason, any way for you to check to see if my account was credited back, or not charged at all? Thanks again
Chris fultz
Reload this Page Help with fuel pump questions
Tags
chris, corvette, dimensions, forum, fultz, grj420, gss340, jetpump, lpe, walbro
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Anyone get the racetronics fuel pump? SpinMonster C5 Tech 12 10-26-2003 10:26 PM
Fuel pump upgrade hypec5 C5 Tech 16 02-12-2003 05:22 PM
Dual 255lph Fuel Pump ????'s Earl H C5 Forced Induction/Nitrous 19 01-15-2003 01:48 PM
ZZ4 questions/issues: headers, water pump, fuel pump, radiator, distributor, carb ... mg62 C3 Tech/Performance 25 05-25-2002 06:28 PM
Need help with 454 crate moter! woodenichols C3 Tech/Performance 13 11-07-2001 11:54 AM
Need help with motor swap jonvolk C4 Tech/Performance 16 09-22-2001 08:08 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
