Need second opinions on BIG Whipple build
Location: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
G5X3 on a 114LSA will bleed off some boost and have a nice lope to it. Or just do what I did and call up comp cams and have your own custom grind done...
I prefer their less aggressive lobes for FI. Easier on the valve train...
Something like...
Intake lobe 3719 232 .575 lift
Exhaust lobe 3653 240 .588 lift
grind it on a 114 or 113LSA...
If you want a more aggressive lobe with more lift...
3726 232 .595 lift
3730 240 .609 lift
you can look at their lobes here..page 29 and 30
http://www.compcams.com/Technical/Ca...obeCatalog.pdf
Custom grind was $406 and I had it in a week...
Something like...
3726 232 .595 lift
3730 240 .609 lift
When are we gonna have some numbers on your monster???? Show me the way, bro....
Thx
St. Jude Donor '08
St. Jude Donor '08
Yes... Who do you think spec'ed the cam for that 8.11@181 stenod red f-bod on ls1tech.....
FMS also spec'ed the cam for harlans 170mph f-bod a few years ago...
Ive never had FMS do any work for me, just relaying info that is known.. good luck on youre choice...
I will vouch for FMS!!
St. Jude Donor '08
That's cool
I actually called and spoke to them about a week ago, but no reponse so far.
I'll give them another call tomorrow
thx
thx
#34
CI 3-5-6-7-8 Veteran
FWIW I'm running a G5-X2 w/ 114 lsa, you can click the link in my sig to hear it. The new yella terras are a great piece and a direct bolt on (unless you have an early LSX w/ perimeter bolt valve covers)
Here's the YTs... too bad I had to cover them up
#35
Harland Sharps are kinda heavy for 7500rpm and boost. I'd go with the rebuilt stockers or something else. I have the HS rockers as well, not bad but too heavy on the nose.
#38
You're Welcome Richard!
I forgot about FMS cams. They use a Cam Motion lobe, which is a bit easier on valvetrain parts than the XE-R lobes from Comp and MUCH easier than the LSK lobes. Allan knows his stuff too. I have a buddy who put a Futral H/C (F13 and a set of Meaux ported heads)setup on his car and is putting 482 to the wheels and is VERY driveable!
#39
St. Jude Donor '17-'18-'19
I went with the following cam and we will see.
FMS FM8 Cam 225/233 .575 on a 113+2 with 1.75 rockers which ends up in around .595 total lift.
I wanted lope but did not want to kill drivability. I have plenty of boost on tap with the 2.8L KB.
#40
I think the cam (228-232) you have would be good on a 114 or 115 LS, Maybe get the AFR 225's. I think your better off staying with the AFR 205s over the dart 225's though. Let the whipple make the power and keep your driveability civilized until you gun it. IMHO
