how 9.sec pass's on auto a4
a4 is a rare tranny !!!! or there is some slow vettes out here HELLO !!! can you here a echo !!!!! i guess most break then go turbo 400 or two speed
I know 2 vendors on this forum,that can build u a tranny to go in the 9s with no problem s,Rpm & Flt chuck Johnson , i do have a Flt tranny just havent been in the 9s with it Yet !!
I had over 40 9-second runs and over 5000 hard street miles last year on my RPM ( Rodney ) 4L60E , the trans was shifting like brand new when I took it out to do the RPM 4L80E conversion ! RPM builds the best in the business , my Rossler never made it past 10 runs back in the day before RPM came along
1 Post
St. Jude Donor '03-'06-'07-'08
That would be for me vs the turbo400.
Why would you change it out for the 4l80?
1 Post
St. Jude Donor '08
At think at the level you are at Roy it probably wouldn't hurt to have a spare tranny/converter incase of breakage. This would save you alot downtime when and if it fails.
Because it was still on the edge at the 9.3-9.5 zone , and I want to put more power to the ground , the opportunity for the 4L80 came up and I took it , at the end of last year I made 10 mid 9-second runs in one day , driving to and from the track , and cruising around all night , sometimes I wish I left the RPM 4L60 in .
Former Vendor
Transmission life expectance is to dependant on other parts. I have guys that have destroyed level V's with around 400RWHP. Here are some things that cause trans failures.
Installation error's such as:
Low fluid level
contaminated coolers
improper tuning
pump breakage (converter no all the way back)
misadjusted shifter linkage
blocked/pinched cooler lines
etc....
Driving errors:
hot lapping
repeated 4-2 downshifts
over temp
neutral drops (Hey I have seen it)
wheel hop
Parts failure:
Converter failure
Converter clutch failure
Forward sprag failure
Output shaft failure
Pump rotor failure
Input drum failure
I could go on and on but the key is how you handle the failure and how fast you can get the car back on the road or track.
Low fluid level
improper tuning
etc....
Driving errors:
hot lapping
over temp
wheel hop
Parts failure:
Converter failure
Pump rotor failure
Input drum failure
