Do I need a BAP with an upgraded pump?
Quick question for you guys, I bought my Procharged Z awhile back and according to the guy that did all the work on it they installed a Racetronix in tank pump. Now if this is true I wouldn't need a BAP to supplement fuel flow correct? I'm only at 5psi with 42lb injectors as is with plans to go about 9-10psi.
Thanks!
Thanks!
Thanks for the quick replys fellas. So next on my mod list 1 7/8 ARH's, 60LB injectors, BAP and a re-tune! Of course after I install my Monster stage 3 and new tires.
AKA "The CLOWN"
It's kinda funny as I have 60lb now but will be upgrading in the near future, not ready to sell just yet!!!
Received 1,762 Likes
If you keep an eye open, 60lb injectors come with the ECS and A&A kits I believe and guys are always upgrading to 80lb or ID1000 injectors and selling their 60s pretty cheap, just a heads up to save you some $$$!
I keep reading about people upgrading their injectors. The guys that are upgrading, how do you know you have to upgrade. Are you logging on HPTUNERS or ELIVE? What are your injector duty cycle? Wouldn't that be the only way to know if you have to upgrade?
Pretty much the Injectors have max duty cycle that you don't want to hit not sure of the % also you can just ask around tell people what your mods are and they can tell you what injectors you will need for the most part.
