C6 oil pan in C5
Old 04-26-2007, 12:57 AM
CrazyChris
CrazyChris's Avatar
Default C6 oil pan in C5
Is anyone using the C6 LS2 oil pan to replace the batwing C5 pan for additional header clearance? Is any ground clearance lost with the deeper C6 pan?
Pros or Cons on the swap?
Old 05-05-2007, 03:40 AM
whitebullet7
whitebullet7's Avatar
i will let you know by monday,i am picking up a c6 oil pan tomorrow and i will put my z back together on sunday
Old 05-05-2007, 12:56 PM
chriswtx
chriswtx's Avatar
Old 05-05-2007, 02:15 PM
BLOWNZO6
Premium Supporting Vendor
BLOWNZO6's Avatar
There are no issues with this.
Contact Valvegod if you need one.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old 05-05-2007, 03:31 PM
Vince99FRC
Vince99FRC's Avatar
I run a C6 oil pan...
Old 05-05-2007, 05:30 PM
longdrive70
Twin Turbo Coupe
Support Corvetteforum!
longdrive70's Avatar
I wish I would have made the switch when I had the TTiX and forged engine put in....it would make the started a lot more accessable
Old 05-05-2007, 05:55 PM
chriswtx
chriswtx's Avatar
Will the C6 Pan also work on an LS1/6 block?? What are the advantages to it??
Old 05-05-2007, 06:28 PM
Tony @ MPH
Supporting Vendor
Tony @ MPH's Avatar
Would love to know more on this mod. ttt
Old 05-05-2007, 06:36 PM
chriswtx
chriswtx's Avatar
The LS2’s new oil pan was developed to ensure oil delivery commensurate with Corvette’s high-performance capability. Extensive track testing has shown the new design to provide better oil control under the extreme demands of high-rpm/high g-force driving maneuvers. The elimination of the previous “gull wing” oil pan design also reduces the engine’s oil capacity from 6.5 quarts to 5.5 quarts with a dry filter.
what I found..
Old 05-05-2007, 06:49 PM
FactoryRaceCar
FactoryRaceCar's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old 05-05-2007, 09:56 PM
BLOWNZO6
BLOWNZO6's Avatar
As I said already.. there are NO issues with using them.
LS1/LS6/LS2 they are all the same. Use away.
This makes turbo access much easier. But as far as it being an "upgrade" I don't see what advantage there is. Working on the TTiX stuff with it is soooo much easier.
Old 05-05-2007, 09:59 PM
chriswtx
chriswtx's Avatar
So for a blower car its not really an upgrade from my stock pan??
Old 05-05-2007, 10:01 PM
BLOWNZO6
BLOWNZO6's Avatar
No. I would not go and swap it... what would the upgrade be? You are losing a quart of oil.
It is nice on the X kit stuff because of the open access it gives you to everything, I guess there may be some other benefits if you road raced the car according to what you found, but I don't know of anyone having problems with a C5 batwing bat, so why change it.
Old 05-05-2007, 11:47 PM
SpeedyD
SpeedyD's Avatar
For anyone doing this I believe you not only need the pan, but the LS2 windage tray and pick-up
Old 05-06-2007, 03:06 PM
frank dupuy
frank dupuy's Avatar
I heat wrapped my uncoated LT headers where they pass next to the wings/oil filter on my pan. I personally noticed a slight reduction in oil temp. I also feel uncoated LT heat will negatively affect the starter/solenoid and therefore the heat should be controlled. I personally have had problems with my solenoid that I attributed to LT heat.
Old 05-06-2007, 09:48 PM
BLOWNZO6
BLOWNZO6's Avatar
BTW, the pick up and the tray are the same as well.
Old 05-07-2007, 08:01 AM
sacsrpc
sacsrpc's Avatar
What is the going price for the ls2 pan?
Old 05-07-2007, 09:20 AM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
APS owners/installers would also benefit from the ls2 pan; sacsrpc, as previously posted, contact valvegod
Old 05-07-2007, 09:53 AM
BLOWNZO6
BLOWNZO6's Avatar
Shaun (aka Valvegod) is in Auburn Hills. He is not more than 15 minutes from you... can can give him a call and go and pick one up.
To C6 oil pan in C5
Quick Reply: C6 oil pan in C5
