Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A & A Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-30-2007, 12:16 PM   #1
EGash
CF Senior Member
Default 10 sec Rearmount Turbo C5 Pics, Videos, Results
Over the past few months I pieced together a rearmount single turbo kit on my C5. The car worked great last year on the nitrous, but I grew tired of filling the bottle, so after some research I decided to take the FI plunge. I removed the G5x3 cam and installed an 02+ LS6 cam w/ Comp 918's. I kept the RPM Trans, Fuddle 3600 Stall convertor, Line Lock, and MT ET streets from last year.
The rest of the turbo kit consists of:
Exhaust/Turbo:
Z06 manifolds
2.5" (x2) to 3" 304ss merge collector
3" 304ss exhaust pipe
Heat Wrap, Exhaust hangers, gaskets, flanges, etc..
PT76GTS
Tial 44 WG .6 bar spring
Oil feed/Return:
-4 SS feed line
Check Valve
-10 SS line (turbo to pump)
REV GP-301 Oil return pump
Various Lines and fittings
Intercooler/Charge pipe:
3" Aluminum Charge pipe (Various bends and straight sections)
Tial 50mm BOV
Top/Bottom Intercooler (27x12x4)
Silicon and T-bolt Clamps
Intake: 4x9"" Filter on turbo
Fuel System/Controls:
Twin intake Walbro pumps
-8 feed line
Billet Rails
Aeromotive 1:1 FPR
Various Fittings
Motron 60# injectors
2 Bar Map sensor
HP Tuners 2 bar SD BlueCat tune 9.5psi Pump Gas
Here are a few work in progress pics
Here's a video from a dyno session
http://videos.streetfire.net/video/3...eb00022fad.htm
The convertor wasn't workng well on the dyno, it slipped a lot and didn't put down much power. Sounds cool though.
Here's a burnout video:
http://videos.streetfire.net/video/9...00017aa42a.htm
And finally...
http://videos.streetfire.net/video/1...00017a25f4.htm
It went 10.85@126 and 6.99@100 on a soft 1.69 60'
It also went 10.86@125.8 later that day. I'll try to scan slips and post up some more videos next week.
I ordered a tighter convertor upgrade from Fuddle, should be here today, hopefully that will help get the 60's back into the low 1.5 like last year. I'm very happy with the car, how it drives, how it moves down the track, and the fact that I still drive it EVERY day with very few issues. Thanks to Dan, RTC, and all my friends who helped me get it together.
Anyway, just thought I'd share. Enjoy.
EGash is online now   Reply With Quote
Old 03-30-2007, 12:31 PM   #2
70Stang
CF Senior Member
Wow looks very similar to our kit!
I know you must love the car!
What numbers do you think it put down on 9PSI?
70Stang is offline   Reply With Quote
Old 03-30-2007, 12:38 PM   #3
EGash
CF Senior Member
I do love it!
I didn't know anyone had a single reamount kit available, the real inspiration for my build was Stealth99, Mike Romain. that car is AWESOME!
It's probably in the 540rwhp range, based on MPH and ET and weight.
Old 03-30-2007, 12:56 PM   #4
70Stang
CF Senior Member
Yeah EGash - Check out our thread about our build...
http://forums.corvetteforum.com/show....php?t=1602063
We both run very similar shops -
Dyno Dynamics
APS
Autronic
Single Rear Mount Z06 kit
Kinda cool!!
Old 03-30-2007, 01:26 PM   #5
EGash
CF Senior Member
Dyno Dynamics
APS
Autronic
Kinda cool!!
Good stuff!
Dyno Dynamics, APS, Autronic. The Australians are on top of it!
I love the Autronic. I ran an SMC on my old DSM into the low 10, low 140's, I also tune on SM2 on a high8/low9 4G63 Conquest. We have many units in Supras and Mitsus running around here. It's simple, reliable, and tuneable. I wish some of the more modern software (AEM) worked as well.
Old 03-30-2007, 02:29 PM   #6
70Stang
CF Senior Member
AEM has cuased us more grief then I care to imagine!
We try to run the SM-4s in everything we build, just gotta get the customers to do the same, LOL!
Nice build EGash.
Old 03-30-2007, 04:31 PM   #7
FactoryRaceCar
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Support Corvetteforum!
FactoryRaceCar's Avatar
Wow! Superb job!
FactoryRaceCar is offline   Reply With Quote
Old 03-30-2007, 04:56 PM   #8
STEALTH 99 C5
CF Senior Member
STEALTH 99 C5's Avatar
Quote:
Eric , Your kit came out nice , I'm glad my car gave you the inspiration to build yours . Good luck with it .
__________________
Cartek-Home of the First 9-sec All-Motor C5 ,http://s170.photobucket.com/albums/u...ealth998-1.mp4
99 C5 FRC
Best ET-8.87 Best MPH-158.63 , 3700+Lbs
Cartek 402, Cartek/STS Rear-Mount Single 88mm Turbo .
RPM 4L80E Transmission+RPM 3.42 Diff
STEALTH 99 C5 is offline   Reply With Quote
Old 03-30-2007, 08:26 PM   #9
EGash
CF Senior Member
Quote:
Thank you. I don't know if you remember talking to me on the phone, but you answered a lot of my questions and really convinced me to go for it. Thanks again, and good luck with your new setup.
Old 03-31-2007, 10:30 AM   #10
Rkreigh
CF Senior Member
very nice work. I like how the turbo is mounted a bit higher than the STS system. very stealthy!!
Rkreigh is offline   Reply With Quote
Old 03-31-2007, 08:50 PM   #11
1FastC61
CF Senior Member
1FastC61's Avatar
Very nice set up. Here is a link to my rear mount turbo set up best to date is 1022 hp to the wheels on pump gas. http://speedwaycorvettes.com/c6/videos/videos.html
http://speedwaycorvettes.com/c6/specs/specsc6.html
Exhaust/Turbo:
Z06 manifolds
PT76GTS
Oil feed/Return:
-4 SS feed line
Check Valve
Tial 50mm BOV
-8 feed line
Billet Rails
Aeromotive 1:1 FPR
Various Fittings
2 Bar Map sensor
And finally...
1FastC61 is offline   Reply With Quote
Old 03-31-2007, 09:17 PM   #12
AustinL911
CF Senior Member
AustinL911's Avatar
Send a message via AIM to AustinL911
What fuel rails are those?
Nice setup too!
AustinL911 is offline   Reply With Quote
Old 03-31-2007, 10:57 PM   #13
ajg1915
CF Senior Member
St. Jude Donor '08
ajg1915's Avatar
Nice pictures and videos.
Did you have to cut the floor in the back to get the turbo in ?
I am entertaining the thought of either an ECS Paxton System or a rear single turbo system like you have.
Got finish up the body kit, suspension, tranny conversion and interior this year and then next year work on some motor options.
Good luck with your set-up.
ajg1915 is offline   Reply With Quote
Old 04-01-2007, 12:12 AM   #14
EGash
CF Senior Member
Quote:
Nice setup too!
Professional Products, Speed inc Budget rail kit. I made up all the lines and plumbing myself.
Thanks,
Old 04-01-2007, 12:25 AM   #15
svtsilverback
CF Member
just saw eric's car and turbo setup tonight at my house. the photos dont do it justice. very clean setup and it sounds great. great job my friend
svtsilverback is offline   Reply With Quote
Old 04-01-2007, 12:37 AM   #16
AustinL911
CF Senior Member
AustinL911's Avatar
Thanks,
Thanks for the info. That blue looks like it'd match my car well. lol.
Old 04-01-2007, 02:13 AM   #17
FRCBobby
Supporting Vendor
FRCBobby's Avatar
Send a message via MSN to FRCBobby
Saw the car at the track last weekend very nice setup.
FRCBobby is offline   Reply With Quote
Old 04-01-2007, 02:51 AM   #18
dwspas
CF Senior Member
dwspas's Avatar
What kind of $$$ does a set up like this run? Interested in doing something like it.
dwspas is offline   Reply With Quote
Old 04-01-2007, 03:54 AM   #19
EGash
CF Senior Member
Quote:
You can get a good idea of what kind of money I have in it by going through my parts list above. I haven't totaled it up, but it's probably in the $5K range on turbo system and fuel system parts. There's nothing exotic, it's all off the shelf parts available from vendors. Good luck if you decide to put together something similiar.
Thanks Brian & Bobby
Old 04-01-2007, 07:48 AM   #20
navy99vert
CF Senior Member
Cruise-In VIII Veteran
navy99vert's Avatar
Dyno Dynamics
APS
Autronic
Kinda cool!!
navy99vert is offline   Reply With Quote
Reload this Page 10 sec Rearmount Turbo C5 Pics, Videos, Results
Tags
10, build, c5, corvette, danrtcyahooca, pics, rear, sec, single, streetfire, systems, turbo, video, videos, work
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
