Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A&A Superchargers
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-18-2007, 11:02 PM   #1
SiegZ06
CF Senior Member
Support Corvetteforum!
SiegZ06's Avatar
Default LS7 swap in a C5 Z06
Anyone done an LS7 swap yet? Does it require similar changes as an LS2 does (knock sensor harness)? What other things need to be changed in the swap?
thanks
SiegZ06 is offline   Reply With Quote
Old 03-18-2007, 11:08 PM   #2
mdhmi
CF Senior Member
mdhmi's Avatar
Send a message via AIM to mdhmi Send a message via Yahoo to mdhmi
I'm sure some folks with post with up the technical specifics, but yes - many people have installed LS7 motors in C5's.
mdhmi is offline   Reply With Quote
Old 03-18-2007, 11:21 PM   #3
gotjuice?
CF Senior Member
St. Jude Donor '13
gotjuice?'s Avatar
Henderson Performance is in the process of finishing up one right now, Complete with dry sump, complete from Catech. Big Bucks!
gotjuice? is offline   Reply With Quote
Old 03-19-2007, 11:17 PM   #4
Mopar Jimmy
CF Senior Member
St. Jude Donor '06
Mopar Jimmy's Avatar
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
Quote:
thanks
Yes, this is easily done however if you want to save yourself around $5,000 and make 100 more rwhp N/A on pump gas, then take a look at this real good:
http://ls1tech.com/forums/showthread.php?t=675896
This is based on the new GM alum L92 block and heads which are LS style motors, all alum. just like on a LS2 motor, and power some of the current GM trucks, and the stroker kits are making 416 cubes and pumping out 550rwhp and 507rwtq for around $8,500 for the complete longblock!
__________________
2006 Black C6 Z06, black powder coated rims, CAI; B&B Bullet Exhaust, and of course 427 Badges ; Mopar Jimmy is back with a daily driver 2008 Dodge Challenger, 450hp Hemi SRT8, runs 12.7s with bolt ons, & a mean, Ralleye Green, 1969 Plymouth Road Runner machine, 600hp 505 ci, black steel wheels & black fiberglass 6-pack lift off hood. Thanks and Praise to GOD!
Mopar Jimmy is offline   Reply With Quote
Old 03-19-2007, 11:37 PM   #5
Skunkworks
CF Senior Member
Skunkworks is offline   Reply With Quote
Old 03-19-2007, 11:46 PM   #6
Tony @ MPH
Supporting Vendor
Tony @ MPH's Avatar
Yeah, I was going to ask... why go LS7 when you can go L92. That L92 car in that post is local and it's a monster. I didn't ask for all the details but it looks like it was virtually all plug and play, with the exception of a few harnesses that looked like they were extended or changed.
Tony @ MPH is offline   Reply With Quote
Old 03-20-2007, 08:15 AM   #7
Bill Reid
CF Senior Member
Bill Reid's Avatar
thanks
If buy a crate LS7 it will require work to get it to work in a C5 with the C5 PCM. The crate LS7 comes with a 58x reluctor wheel and a 4x trigger cam sprocket. A 24x reluctor wheel would have to be swapped in which requires disassembly of the short block... unless someone came out with a little black box to make the crank and cam signal compatible with the C5 PCM. Its been awhile since I was involved in a swap. The cam sprocket would need to be swapped over to the old stlye LS2. I forget if the crank and cam sensors would need to be replaced with the older LS2 variety. Road Rebel could elaborate on that. You would need to relocate your battery to the trunk, remove the battery tray, and fab up a bracket assembly to hold an oil tank. Several manu's make them or you could go with a C6Z06 tank... which comes with a dip stick and a spot to mount your oil temp sender. You would need to fab oil lines. Yes, cam sensor extention, knock sensor relocation, throttle body adaptor harnesses, and injector pigtails would be necessary. There are alot of other smaller details but this kinda gives you an idea...
... or you could scratch build an LS7 wet sump motor...
...or you could build an L92 like the guys are saying...
Bill
Bill Reid is offline   Reply With Quote
Old 03-20-2007, 09:00 AM   #8
thegame
CF Senior Member
thegame's Avatar
Send a message via AIM to thegame
Quote:
Is that L92 forged ?
thegame is offline   Reply With Quote
Old 03-20-2007, 09:07 AM   #9
Mopar Jimmy
CF Senior Member
St. Jude Donor '06
Quote:
Yes, it SURE IS forged, including the 4.00 stroker crank, where 99% of forged 346/7 motors for sale for f/i from LSx tuners, just used a polished stock LS1/6 crank, b/c the stock cranks can handle a TON of POWER and no need to go to the extra expense for a forged stock displacment crank!!!
Old 03-20-2007, 09:12 AM   #10
BLOWNZO6
Premium Supporting Vendor
BLOWNZO6's Avatar
Send a message via AIM to BLOWNZO6
If you want the 427 cubes.. an sleeved LS2 427 is a great option for you as well.
There is a lot better options for your money than using an LS7.
If it makes you feel better you can put the LS7 fuel rail covers on it.
If you wanted to put an engine together from scratch with 427 cubes you can do it for about 10k. There are readily available harnesses for all sensors, etc. etc.
This would be a plug an play option for you.
The first thing I tell people when they say they want to put an LS7 in an LS1 vehicle... go ahead an spend $15,000 on a motor, receive it and immediately tear it down to bare bolts to change the crank reluctor wheel.. That alone would make be just build a stand alone motor.
__________________
1964 Coupe
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
BLOWNZO6 is offline   Reply With Quote
Old 03-20-2007, 09:19 AM   #11
thegame
CF Senior Member
thegame's Avatar
That's a pretty sick deal for $8,500!!
Old 03-20-2007, 07:42 PM   #12
7LitreC5
CF Senior Member
7LitreC5's Avatar
Just as a data point I am doing a wet sump 427 using a LS7 block, ported L92s, and the L76 intake. I have $9800 in the shortblock, heads, intake, adaptor harnesses, gaskets, etc. The $10k that BLOWNZ06 put in his post is right on.
__________________
2002 Coupe
Mods: Wet sump 427, ported L76, Livernois L92 heads, Katech valve covers/coil brackets, SuperMaxx, C6Z shifter, Z06 cat-back, mini-tub, HRE 545R wheels, 3.73 gears, Wilwood brakes, DeWitts radiator, Vette-HID, Corbeau A4, Pfadt JOC.
7LitreC5 is offline   Reply With Quote
Old 03-20-2007, 08:38 PM   #13
99blackFRC
CF Senior Member
99blackFRC's Avatar
Send a message via AIM to 99blackFRC
thanks
We've done it. Like others are saying, there are alot of options out there these days - especially knowing that you'd have to tear down the motor to swap out reluctor wheels anyway. All depends on what you're after really..
Here's the one we did for a client on the rollers this past weekend.
http://www.youtube.com/watch?v=33heu7zDTvg
__________________
-Tom
99blackFRC is offline   Reply With Quote
Old 04-01-2007, 10:20 PM   #14
SiegZ06
CF Senior Member
SiegZ06's Avatar
ttt
Old 04-01-2007, 11:02 PM   #15
SteveDotenMotorsports
Supporting Vendor
Cruise-In VII Veteran
SteveDotenMotorsports's Avatar
Bill
is the 4x cam sprocket the same used on the '07 centerbolt LS2 cam sprockets?
SteveDotenMotorsports is offline   Reply With Quote
Old 04-02-2007, 05:31 PM   #16
SiegZ06
CF Senior Member
SiegZ06's Avatar
Any good builders out there with crate L92 motors? Are they a direct bolt in replacement for the LS6 or does it require other mods?
Old 04-02-2007, 07:00 PM   #17
roythomas
CF Senior Member
roythomas's Avatar
roythomas
huge couto's to ls2 sleved to 427 two years & very happy
roythomas is offline   Reply With Quote
Old 04-02-2007, 08:53 PM   #18
LS7 C5
CF Senior Member
LS7 C5's Avatar
Try Texas Speed & Performance, they are a forum sponsor listed on the left side of your screen.
LS7 C5 is offline   Reply With Quote
Reload this Page LS7 swap in a C5 Z06
Tags
2000, 2002, 427, build, c5, corvette, engine, kits, ls2, ls7, skunkworks, sprockets, stroker, swap, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
$12,995 for a complete LS7 engine 2000Firehawk C6 Z06 Discussion 46 07-31-2005 06:24 PM
c6 z06 to have targa lowellmstevens C6 Z06 Discussion 35 06-05-2005 03:43 PM
LS2 into C5 swap FLYNAVY30 C5 Tech 40 05-04-2005 05:20 PM
No need to baby anymore: LS7 crate engine will be avail. Soon! Alex1217 C5 General 19 03-22-2005 10:37 PM
Andy finished my C5R 427 F1-R in time for my Birthday…It rocks-He’s the Greatest! 7.0sc SuperVette C5 Tech 28 01-19-2005 12:27 AM
Z07 engine bolt in swap into my C5 CJS C5 Tech 10 12-15-2004 08:35 PM
Its here OMG OMG vetmts C6 Z06 Discussion 118 11-13-2004 02:04 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
