Is it worth removing the stock cats for straight pipes?
Currently I have an 02 Z06 with the following mods:
I/C Maggie w/3.2 pulley
Meth injection
TPIS headers
Stock cats
TI mufflers
Will I pick up much hp/tq if I remove the stock cats and weld in some straight pipes?
Meth injection
TPIS headers
Stock cats
TI mufflers
No. Stock cats are fairly restrictive. Metalic cats like Bassanis flow much better than stock cats, about 480 cfm which is almost as good as a high perf muffler (500+ cfm). Stock cats dont hold up well under rich conditions like when your running 11.5:1 under 10 psi. As soon as you get out of the boost and AF ratio gets back to about 14.7:1, all the gas that has accumulated in the cats from the run under boost starts to burn and heat up the cats. A stock cat will melt down sooner under these conditions than a metalic cat.
