** Official FI Owners Club **
01-01-2007, 07:18 PM
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
01-01-2007, 07:19 PM
98 Vert - A&A Vortech SQ - 5psi - 465rwhp/435rwtq
01-01-2007, 07:33 PM
St. Jude Donor '06-'07
STS TT, RPM Level V trans
01-01-2007, 07:37 PM
St. Jude Donor '08
'99 FRC A&A Vortech T trim on a 402/650 rwhp, 580 rwtq
01-01-2007, 08:07 PM
Check out my sig please..
01-01-2007, 08:37 PM
PTK. Stock bottom end. Base turbos. Awaiting shippment of kit. Dyno and track numbers to follow.
ECS D1 Procharger, stock shortblock, 317 heads, Cartek 2X cam, LT's, 10# boost,no meth, 592rwhp 527rwtq.
Jer.
01-01-2007, 08:46 PM
APS on the way.
In the past on this car:
Vortech kit with V2 SQ SC-Trim head unit
RMCR kit with V2 SQ T-Trim head unit
01-01-2007, 08:52 PM
ECS D1SC kit on the way.... Set up for install at FLP Jan. 29th
I will post #'s then. Installing on stock bottom 01' vert.
01-01-2007, 09:00 PM
paxton novi 2000
402 in the works, and novi 2000 on the way!!!
01-01-2007, 09:04 PM
383 Stroker, F1R Procharger, Meth/Alky..755rwhp 675 rwtq. 10.38@134
01-01-2007, 09:17 PM
01-01-2007, 09:31 PM
03 coupe A&A S trim 490rwhp/430 rwtq 5psi. Smaller pulley on the way and Meth.
01-01-2007, 09:36 PM
St. Jude Donor '09
A&A 6 rib D1SC w/ 4.10 pulley, ECS Dual Nozzle Meth Kit, LGM Longtube pros w/hi flo cats, B&B Bullets, Kenne Bell Boosta Pump, Thunder Racing Racetronix Harness, HPTuners PRo, 60# Mot. Injectors
Shooting for 650 rwhp
01-01-2007, 10:16 PM
St. Jude Donor '07-'08
TTi Stage 1 444 rwhp 499 rwtq
01-01-2007, 11:27 PM
99 C5 hardtop, ECS D-1, ECS Dual Port Alky Kit, A&A Blower Cam, stock bottom end, stock heads, Stainless Works Headers....@585 rwhp
01-01-2007, 11:31 PM
01-02-2007, 01:10 AM
2017 C5 of the Year Finalist
St. Jude Donor '08
I have a Carrol Supercharger Bracket with a 45 MM cogged belt. I have a Vortech T trim with a custom made air to water aftercooler, pipes, and 2 heat exchangers. I also run an Alky control meth injection kit, with a steady supply of Torco in every tank.
#s in Sig...
JB
01-02-2007, 01:43 AM
ECS installed, ECS Paxton Novi 2000 here. Installed one year ago. Bullet proof !!
Barry
01-02-2007, 02:01 AM
LPE TT 346 cids - 700 rwhp, 680 rwtq
